Bug in Sync 3.4.21194 with Camera?
Hi,
referring to this topic from me see link I would like to give feedback again.
I updated again to Sync 3.4.21194 and again the camera turned black and white similar to a surveillance camera. Then I downgraded to 3.4.21098 and the camera works correctly again. I think there is a bug in the version here, in whatever context. It’s not an original Ford camera.
This has been reported across several forums now, so I would say something changed or there is a ‘bug’ in 3.4.21194. As far a I can tell it is only with aftermarket equipment. There is no mention of a solution.
Thank you for letting us know about that.
I think it’s worth mentioning in the build specific thread, if it has not been covered yet.
I will search for that later, and post in the thread accordingly if nothing is found.
Here is one…
Enabling Park Assist in Sync 3 (For those that have done a Sync 2 > Sync 3 Upgrade) - Ford / Sync 3 - CyanLabs Official Community
The same issue has appeared on F150Forum recently, no resolution other than downgrade the software. This is only with aftermarket cameras as far as I know…
Issues with South African ford rangers have been mentioned. I do wonder if these vehicles have had after market cameras fitted now!
