Afternoon all, I done the bvc to scyn3 retro fit. All works fine expect, I can’t set time via GPS. when the ignition is off the time is wrong, but with ignition on time is correct (set manually)
I have used 3rd party gps antenna and now have oem.
Apim hidden settings shows that I can see satellites.
Any body got any ideas ?
Old SYNC Version: 2.216223
New SYNC Version: 3.4.23088
GPS data unavailable please try again later.
Do you have FORScan? Usually this winds up being the Clock Master being set wrong but you need FORScan and an adapter to update it.
EDIT: You might be able to see what the clock master is set to in the APIM in the secret menu under APIM Diagnostics > Configuration, but won’t be able to change it.
I believe my Clock Master is set correctly, it’s set to 68. Which is for BCM being master. I’ve got cables and forscan.
68=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
This is correct for a C1CMA vehicle like the 2011 Focus.
You need to downgrade he Sync application to 3.4.21265. The non-nav clock issue is a documented bug in the later Sync 3 application versions.
@F150Chief thank you so much, this resolved the issue. Something so small but was bugging me so much
