Bypass 'vehicle in motion' on bench setup
I built a sync3 bench tester with a microcontroller + CAN controller, OBD ELM cable… etc etc etc. I’ll spare you the technical details.
One thing i’m missing in my script is injecting a CAN message to override the ‘in-motion’ lock, so I can update via USB on the bench.
I tried injecting vehicle speed, but… no dice.
    unsigned char vehicleSpeed[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
    CAN.sendMsgBuf(0x215, 0, 8, vehicleSpeed);
    delay(15);
It’s a 2019 apim with 2015 asbuilt (manual transmission, so it’s not looking for ‘park’)
However, this script needs to work on 2016-2021 APIMs
FWIW - I am self-taught with a background in nerdy things, first time on here
Old SYNC Version: 3.4
N/A
how did you solved it?
        CAN.sendMsgBuf(0x130, 0, 8, vehicleSpeed);
        delay(10);
looked at the TX/RX on the serial monitor output in arduino IDE from the CAN controller
I take that back actually. It was working.. but after a few APIM power cycles - it stopped working. (The APIM thinks it’s in motion.)
Not sure if this is overly technical for this forum, or if I am in fact in the right place; “latest posts” on here shows threads like “How 2 get radio 2 work I push buttons”
Fuckin technology how does it work
To clarify, my bench build works. I can connect to forscan, flash asbuilt, and fully boot any 2016-2021 sync3. It’s portable in a sealed junction box with 20v rechargeable power stepped down, or can switch to power supply.
What I’m trying to do now is really just ‘for fun’ functionality
3 days no bites… do we not have any certified nerds here?
We’re here. The certified nerds are probably too busy fixing things to respond. :joy: Most of us are running more advanced test benches rather than emulating CAN messages with an MCP2515 and Arduino.
LOL hey, I came up with something based on what I had in my garage - and it does exactly what I need it to do. I don’t see why you would make something more advanced just to boot it / flash it?
But hey i wouldn’t know
Okay …seems like people are too cool around here for me. Thanks for the help :+1:t2:
