Calibration File Requests
Hello im trying to update the firmware on my Ford Focus 2012 TCM and retrain it in hopes of it not sticking between 1st and 2nd gear. Im not sure if it was done when the transmission was replaced.
The .VBF Calibration Files I need are:
AE8P-7J244-AB.VBF
FV6P-7J104-GE.VBF
If you’ve had a gearbox or clutch pack replaced it should have been retrained. Sometimes you just have to drive it like you stole it as well as drive like ya nan
Hi, Looking for
GB5T-14G374-CD
GB5T-14G375-BA
GB5T-14G375-BB
Thanks!
Z
It doesn’t need to update HCM FW on adaptive bi-xenon upgrade.
You should foce HCM in Alignment And Calibration mode, and follow the instruction,
Or directly change as-built code
734-01-01 xxx7 xxxx xxxx
I NEED THIS FILES PLZ
CV4T-14F623-AA - SBL
CV4T-14F621-AC
CV4T-14F622-AB
I do not see these available.
Probably a long shot but I’m curious if anyone has leads on the Focus Mk3 CCM calibration files. The current Part # I have documented is BV6T-14B588-BF.
I was able to track down some of the files, but not all. These are the ones I have now:
AG9N-14C175-BA
BV6T-14C173-BC
BV6T-14C411-BA
But supposedly there should be the following with that as well which I’m missing and haven’t been able to surface:
BV6T-14C172-BF
Likewise if there’s any leads on the calibration files for the actual radar module (on the Mk3 apparently this was separate from the CCM which sits inside the cabin), that’d be super helpful. The one part # I’ve been able to find for this is BV6T-9G853-BA
I’ve been slowly digging in to seeing if I can get adaptive cruise retrofitted to my '13 C-Max. The BCM seems to have the option for it and rightfully complains about not having a CCM to communicate with when enabled. Haven’t had a chance to check the ABS module yet for the necessary options but hopefully that exists. I have a clone UCDS adapter coming in that will hopefully let me check the Direct Config stuff.
But I managed to track down a cheap CCM from Land Rover/Jaguar and based purely on a visible inspection it appears to be identical to the Ford module and some LR forum discussions leads to some information indicating for the applicable models there that they share a similar configuration/calibration architecture to the Focus. With all of my Google-Fu exhausted, seems like nobody has tried to reflash one of these, though the old Mk3 setup seemed to be rare to begin with. But there are plenty of examples of people using radar modules from other makes such as Volvo and flashing Ford firmware successfully so the CCM potentially applies as well. And the price was cheap enough that I was willing to gamble on the attempt.
I can’t find this available.
Please share the file 1U5T-14G374-E*
Uploading: 20230713_130717.jpg…
If I replace the file 1U5T-14G374-DA with the file 1U5T-14G374-EH manually nothing bad will happen? Is it possible to change one file?
Keep the file releases together as specified in the article.
APIM Firmware Production Releases - Ford / Information - CyanLabs Official Community
Hello,
I want to update my PRE-18.5 to be able to access 7D0-09-xx. My apologies, I’ve seen these files requested but cannot find the links.
Part number: JL7T-14G371-CCC
Calibration level: JL7T-14G371-CCG
Strategy : GB5T-14G374-CD
Calibration: GB5T-14G375-CA
Files needed:
1U5T-14G374-DA
1U5T-14G375-DA
JB5T-14G379-BA
Thank you!
What feature are you trying to get to work? I can tell you that not one feature in the 7D0-09 blocks will work in a Flex. They are a CGEA 1.2 network and these features are not built into the module calibrations.
Hi, I would be grateful for these files:
SBL: F1BT-14C047-AD
Strategy (F188): F1BT-14C044-ZAK
Strategy (F120): F1BT-14G316-AF
Strategy (F121): F1BT-14G316-CD
Strategy (F122): F1BT-14G316-DC
ECU Configuration/Base Configuration (CAN, F10A): F1ET-14C654-CL
Thank you in advance!
Hello,
Could someone provide me a link to download the following calibration file? I’m unable to download it from Motorcraft site now. Thank you.
GV6T-14C097-AA.vbf
Not available.
Hi
Can you help me?
I’m unable to download it from Motorcraft .
Thank you.
M1BT-14C651-AB
M1BT-18D619-AB
These do not appear to be available.
Hello. Please advise calibration for part # DB5T-14D212-AE. I was thinking about making the following firmware D1BT-14D544-AZ, E1BT-14D544-AZ. I couldn’t find the files. If you can, tell me which ones are better to install and if you can, share the files. I’ve been racking my brains for 2 weeks now on how to do this. Thank you
Hi. Can I get file ks7t-14d099-fb? I need this for acm.
