Calibration File Requests
I sent you a PM
Does anyone know where I can download this file: ab39-14c097-aa.vbf
[LINK REMOVED]
Thank you very, very much.
Hi,
Thanks for trying.
Hi to all. I need calibration files for 7G9T-14A073-CA . Problem is that i did update with forscan and folow forscan update bcm to calibration level 7G9T-14A073-CF, strategy 7G9T-14C094-AG , calibration 7G9T-14C095-AG and after that i lost tpms in bcm. I search for orginal maybe old files to update to have again tpms
File is shown as not available on Ford servers.
can someone please help get the following calibration files i need to recover my two old apims both detected on forscan but both show black screens one is a 16 the other 17
GB5T-14G376-AA
GB5T-14G374-CA
GB5T-14G375-DA
GB5T-14G375-FA
GB5T-14G375-CA
GB5T-14G374-AF
GB5T-14G374-CD
GB5T-14G375-BA
GB5T-14G375-BB
GB5T-14G374-CB
GB5T-14G379-AA
GB5T-14G379-BA
See your PM…
Same story here, only one APIM with black screen to fix though:
required files:
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-FA
GB5T-14G379-AA
HB5T-14G379-BA
Any idea what calibration level I should chose? Factory is the one selected but the screen is black, so not sure. Other options are:
HS7T-14G371-FAP
HS7T-14G371-FAR
APIM Hardware sticker data:
PartNo HM5T-14G370-GNF
AssyNo (Sticker on the other side): HS7T-14G371-FAD
Mfg. Date 11/29/16
If the files are not available anymore I’m willing to try different/newer files if this helps.
Thanks so much!
See your PM…
You’re a saint, will try tomorrow first thing in the morning and report back!
Firmware updates worked, screen stays black, I even tried to upgrade to my18.5 files but this made no difference:
I’ll now solder wires to the eMMC testpoints and write a known good image to the storage via dd - if this does not work the unit goes to scrap :frowning:
Do you have a different screen? Did you try resetting the APIM with the screen?
Connect the screen, force reset the APIM with FORScan and power cycle the APIM.
No I have only one screen, copying the eMMC contents from the good unit fixed the problem - or so I thought. Soon enough the screen did not light up after a reset (key combo or forscan) or wakeup from sleep (ign off, open- then close door). Usually this could be fixed by disconnecting the wireing harness plug. I think the hardware is faulty. Btw: the eMMC read and write speeds can be bumped from 3 MB/s to 12 MB/s by connecting DAT1,2 & 3 as well, this brings the time for the transfer of 64GB from 6h down to 1,5h.
Anyways thanks so much for the files, the’ll come in handy for future 3.4 mods/apps as you included also the my18.5 ones.
Hi, I’m trying to update IPC module.
I need :
K1BT-14C026-EAK
K1BT-14C088-EAE
K1BT-14C088-EBG
K1BT-14C088-ECD
K1BT-14C088-EDF
Can someone help me?
I do not see these available, and historically a good reason for this. The IPC modules can be a bit finicky and Ford has not readily supplied files for these. However, with patience and the proper adapter they can be updated without issues. Make sure you follow the FORScan recommendations and maybe search the FORScan website forums for the specific IPC and files. You will not be able to obtain the files there, however.
You did try to download these thru the FORScan app, right?
Thanks for the reply.
Yes, I tried but they are not available. I will wait with my Obdlink Ex ready.
I ask you for another info…
Is possible to restore/update the car map with forscan? (ECU)
Use the Syn3Updater for that, FORScan does not do that.
1U5T-14G375-DA.VBF
1U5T-14G374-EH.VBF
GB5T-14G375-DA.VBF
GB5T-14G375-CA.VBF
Could I get these apim calibration files
