Calibration File Requests
Hallo
Ich bräuchte die Calibration Files
Mein Apim HB5T-14G371-FCA
Kuga Jahr 2017
Es müßten die sein.
Kann mir die jemand besorgen?
GB5T-14G376-AA.VBF
1U5T-14G374-EL.VBF
1U5T-14G375-HA.VBF
GB5T-14G379-AA.VBF
5U5T-14G379-BA.VBF
Danke Schön
Hi
I need the calibration files
My Apim HB5T-14G371-FCA
Kuga Year 2017
It would have to be them.
Can someone get me that?
GB5T-14G376-AA.VBF
1U5T-14G374-EL.VBF
1U5T-14G375-HA.VBF
GB5T-14G379-AA.VBF
5U5T-14G379-BA.VBF
Thank you very much
@steven3310 @Niels
Your unit was probably OEM with this firmware:
3.0 APIM NAV & NON-NAV Unit Firmware (Production Release, 2017-Pre-2018.5, H-Early J Series)
(Originally Found On 2017/Early 2018 Units That Ship with 2 USB Ports on Back)
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-HA
GB5T-14G379-AA
HB5T-14G379-BA
You should try this first. It will upgrade you to MY18.5.
3.2/3.3 APIM NAV & NON-NAV Unit Firmware (Production Release, 2018.5, J-Early K Series)
GB5T-14G376-AA
1U5T-14G374-DA
1U5T-14G375-HA
GB5T-14G379-AA
JB5T-14G379-BA
Thank you , I will try in the morning.
Thank you! It works again.
Only the u2100 error, even after reloading asbuild and factory reset. Everything works fine, so no problem.
If I understand correctly the 374-DA is a bit old and the 374-EL is more recent. Is there a workaround so I can update? I ask this because I would like to use mods, I understand I need an Ex version.
Edit: I also tried the -EK version, also no boot.
Also I think the unit has one usb, if that matters.
Hi all. Someone have this calibration files for APIM unit? I can’t buy forscan license because the war and can’t download those VBF, someone could share with me? Thanks in advance
Post you APIM asbuilt. Did you fill in the 7D0-08-xx and 7d0-09-xx lines?
This is MY18.5.
3.2/3.3 APIM NAV & NON-NAV Unit Firmware (Production Release, 2018.5 , J-Early K Series)
GB5T-14G376-AA
1U5T-14G374-DA
1U5T-14G375-HA
GB5T-14G379-AA
JB5T-14G379-BA
Your 2018 MY Fiesta will not have any additional features with newer firmware. You should be able to run the desired mods with this firmware, unless the mod specifically states a requirement for higher versions.
If you wish to discuss the mods further, please do so on the FMods site.
You cannot upgrade firmware without a paid FORScan license.
FORScan Licensing Sales and Support, March 15, 2022 - Ford / Other - CyanLabs Official Community
Do you have HB5T-14G375-BA file? I’m trying to restore a bricked APIM. I used HB5T-14G375-FA and it works but i dont think thats the proper calibration for my APIM so id like to correct it
Deleted
Thank you! Am I correct for thinking that i need this file vs the HB5T-14G375-FA?
Also can i just flash this single file or do i need to reflash them all?
Since you are in the US, you will use HB5T-14G375-DA or HB5T-14G375-FA. You will use the NON-Nav version of the 374 file, HB5T-14G374-CA.
See the attached file for guidelines…
APIM Firmware Flash Rescue.pdf (50.1 KB)
So the screenshot I posted above is correct already? I was under the impression that HB5T-14G375-DA was for apims with navagation and HB5T-14G375-BA was for non nav apims. My unit is non nav. I attached the file I was going off of.
APIM Firmware Flash Rescue Gen 2 (PRE-2018.5).txt (1.2 KB)
The APIM Firmware Flash Rescue pdf you posted states this
GB5T-14G376-AA
HB5T-14G374-CA
HB5T-14G375-DA or HB5T-14G375-FA (HB5T-14G375-CA NON-NAV)
GB5T-14G379-AA
HB5T-14G379-BA
And the one I posted sates this
For NON-NAV:
SBL: (shouldn’t have to change this) GB5T-14G376-AA.VBF
Strat: HB5T-14G374-CA.VBF
Cal: HB5T-14G375-BA.VBF
So based off the PDF you posted I think I need HB5T-14G375-CA but based off the one I posted I need HB5T-14G375-BA. Based off your respeonse above you said I need HB5T-14G375-DA or HB5T-14G375-FA so I’m completely lost on what 375 file I need. Both nav and non nav use the same 374 file per the Flash rescue guides so im lost when you say I need the NON-Nav version because they both use the same HB5T-14G374-CA.
Use HB5T-14G375-DA or -FA and HB5T-14G374-CA. I do no have -DA
Sounds good. The screenshot I posted is after I unbricked it and the apim is working again. Unfortunately I didn’t take a screenshot of what the original strategies were but I used the files @Mr.Queequeg uploaded in post 645 here to unbrick mine Updating APIM Firmware (Calibration Files) - Ford / Sync 3 - CyanLabs Official Community
It worked but his apim was a nav apim so I’m thinking I unbricked mine using Nav files… but it works so… Sorry for all the confusion, I just want this to be right.
Should I leave it as is in the screenshot or change the HB5T-14G375-FA to HB5T-14G375-DA? what is the difference between the 2? In the PDF you sent me it says HB5T-14G375-CA is for Non nav
There is really no issue to leave it as is, as there is not a significant difference in the calibrations. The -CA file is just optimized for the NON-NAV systems.
Can you send me the CA file please? And is it okay to just flash the file by itself since the rest are already correct or do I have to reflash them all? Is there any difference between the BA and CA?
Can I update to these files here Updating APIM Firmware (Calibration Files) - #748 by F150Chief
Yes.
Any benefits to that? And in that case do you have 1U5T-14G375-CA
