Can I save bricked APIM
These are both NON-NAV APIMS…they are at various firmware levels but should work fine other than no navigation.
KU5T-14G371-BDF
VY65024A
<d2p1:PartitionHealth type=“/fs/images/” total=“10G” available=“8.8G”/>
Sync 3.4 with later firmware.
3U5T-14G371-LDB
WXC2FLMX
The firmware would need to be upgraded to MY18.5+ to load Sync 3.4 and work with a Sync 4 screen.
Ah good thanks for verifying those. I didn’t think they were nav, after reviewing the interrogator logs. But the part numbers on the outside were misleading.
All things considered, Syn3 updated works pretty nice. I had trouble with interrogator not working but your old sync 3 version determines which interrogator package it gives you.
Any luck with the as built data for the nav?
Notes on your asbuilt:
You could probably disable Travel Link if you are not subscribed to it.
Trailer Backup Assist (TBA), does a 2013 have this?
7D0G3G12154520300A5 is copied from Sync 2? It will not work.
Try this:
7D0G3G1 0000 0003 00xx (xx = checksum bits, let FORScan calculate these.)
7D0G4G10103050000E5 is copied from Sync 2? It will not work.
Try this:
7D0G4G1 0100 0003 00xx
7D0G4G20001DE. This is in conflict with the PDC display in 7D0G1G. This indicates that it is disabled…2=PDC HMI Disabled, RVC Present, Illumination FNA.
If you have the sensors and camera, it should be a value of ‘A’.
You will need to check the values for Blocks 5 and 7 from a 2017 or 18 F series superduty. These must match your vehicle to make sure the nav tracking is correct.
No, I don’t have Travel Link, and TBA didn’t come out until 2016.
I made the appropriate fixes, and copied blocks 5 and 7 from the AB from 2017 F250 Lariat with navigation for sale online 1FT7W2BT7HED96717. Did a master reset and…as for the PDC (parking sensors), changing from 0 to A didn’t seem to change anything. FYI I have a broken parking sensor but the other 3 work. So maybe the error message precludes something from happening.
The nav we will see when I go to work. The AB from the 2017 had a tire circumference of A5 but my Sumitomo Encounter AT LT275/65/18 tires are listed at 651 rev/mile or 100.5” circumferfence so that would be 9B?
Looks like the nav tweaks are working. I didn’t wait until it had found my starting position before driving, so it was wonky at first. But it must update GPS pos periodically when driving, like at red lights, because it was good at some point, I failed to notice exactly when.
