Cannot update sync via usb
Trying to update sync from 3.0.17276 to the most current update, each time I plug in the USB I get “Installation paused - the usb storage device has been changed or removed. Installation will resume when the device is re-inserted”. I’ve tried just about everything I’ve been able to read off of reddit and this website, whenever I master reset sync the previous owners phones are still on sync and every time I delete them and restart the car they come right back. I tried doing an interrogation log but I can’t complete an installation. All files are downloading successfully to the USB. Is my APIM just shot?
Old SYNC Version: 3.0.17276
New SYNC Version: 3.0.17276
Version: 3.0.17276
; CyanLabs Syn3Updater 2.12.5.0 Stable - reformat  Mode - Sync 3.4.23188 NA
FILES (5)
[3/22/2024 10:30:42 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[3/22/2024 10:30:42 PM] Install Mode: Auto-Detect (reformat) Forced: False
[3/22/2024 10:30:42 PM] MY20 Protection: Auto-Detect
[3/22/2024 10:30:42 PM] Formatting USB drive
[3/22/2024 10:30:42 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[3/22/2024 10:30:50 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[3/22/2024 10:30:50 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[3/22/2024 10:30:50 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/22/2024 10:30:50 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[3/22/2024 10:30:50 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/22/2024 10:30:51 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[3/22/2024 10:30:51 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/22/2024 10:30:53 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[3/22/2024 10:30:53 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/22/2024 10:30:55 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[3/22/2024 10:30:55 PM] Preparing USB drive
[3/22/2024 10:30:55 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[3/22/2024 10:30:55 PM] Copying: 1u5t-14g386-cb.tar.gz
[3/22/2024 10:30:55 PM] Validating: 1u5t-14g386-cb.tar.gz
[3/22/2024 10:30:55 PM] Copied: 1u5t-14g386-cb.tar.gz
[3/22/2024 10:30:55 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/22/2024 10:30:55 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/22/2024 10:30:55 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/22/2024 10:30:55 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/22/2024 10:30:55 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/22/2024 10:30:55 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/22/2024 10:31:16 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/22/2024 10:31:17 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[3/22/2024 10:31:17 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/22/2024 10:31:17 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/22/2024 10:31:46 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/22/2024 10:31:47 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[3/22/2024 10:31:47 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/22/2024 10:31:47 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/22/2024 10:32:33 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/22/2024 10:32:37 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[3/22/2024 10:32:37 PM] Generating reformat.lst
[3/22/2024 10:32:37 PM] Generating autoinstall.lst
[3/22/2024 10:32:37 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
First question, do you have anything else plugged into the other USB port?
Phone cables even without a phone having off them can cause problems sometime, so you need to remove anything else that’s plugged in.
If you don’t, I would be looking at the USB media hub/port first there’s a good chance that the port is flaky.
We have had many reports like yours (you have already seen then) and I think with THAT particular build. The fact the Master Reset does not clear any data is an indication the APIM is unhealthy, that’s not a good sign.
As far as I remember, none of those reports were resolved by other than replacing the APIM.
All usb ports have nothing in them, if I plug in my phone it will charge but apple carplay wont even open up I’ll probably try a new usb hub before biting the bullet on a new APIM - thank you
Bummer, thanks for the reply man
