I am using a 64 gb USB, is that the issues or is there something wrong with the download?
This has been documented and discussed numerous times on the forum and on the discord. Ford’s servers aren’t all too reliable so sometimes the connection is dropped. You just have to keep trying and eventually it should finish the downloads. That or manually download the files using the links from the app and place the downloaded files in the Syn3Updater folder.
Thank you for the information! I will keep trying to download it
If you keep failing, as advised before, try downloading manually… Networking hiccups may be handled better in a browser…
You only need to download them manually, all the other process would be automated.
Syn3Updater will not download them again if they are there, it will just validate them and create the USB.
