Can't find current version in Syn3Updater
What is your SYNC Region? Eu
Do you have Navigation? Yes
What region is your SYNC APIM? EU
What was your old SYNC Version? 3.08.15128.EA.10_PRODUCT
Nav version 5.67.2
Hi.
Can’t find my current version in Syn3Updater.
Which should i choose?
Want to update to 3.4
This doesn’t look like Sync 3 send a photo of your version information.
Or is this sync 2 , version 3 ?
Yes that is not SYNC 3, that’s SYNC 2, please read our documentation.
And upgrade to 3.4 needs hardware?
Again please read the documentation. If you have sync 2 you can not update to sync 3, new hardware is required.
Yes, you will need to retrofit a Sync 3 APIM and new USB hub. The USB hub might require a new wire harness jumper depending on the vehicle. If you go this route, purchase a 2017 or newer APIM.
All maps for Sync 2 are on SD cards and are licensed. (Need to pay for them…at least in the US.) It looks like your maps are F5? Also, there is an update for Sync 2 (3.10). This is the last update offered by Ford in support of Sync 2.
