Can't Get Climate Control Working
We recently upgraded to Sync 3 and my own screen climate control is no longer working. My husband and I are trying to fiddle around with the APIM configuration but cant quite find the right settings to change. We have a 2016 Explorer Limited with heated and cooled seats.
Install Type: Unknown
Old SYNC Version: 2.0
911 assistant unavailable
USB Hub not supported
Can you export your APIM config with ForScan and post it?
You cannot load the Sync2/MFT factory config into your vehicle, different APIM OS and its looking for different hardware.
The USB hub error is due to the fact that you need an H series hub for full compatibility with 3.4.x
