Can't Update to Sync 3.4 to latest Stable Build
I’ve tried with three different USB thumb drives (all different manufacturers and different capacities 16GB, 32GB, and 128GB) and keep running into “PKG_ERR03”
Install Type: Unknown
Old SYNC Version: 3.4.20196
PKG_ERR03
Version: 3.4.20196
Model: ADATA USB Flash Drive USB Device
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall Mode - Sync 3.4.23188 NA
FILES (4)
[2/9/2024 9:14:11 AM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Keep Existing Maps
[2/9/2024 9:14:11 AM] Install Mode: Auto-Detect (autoinstall) Forced: False
[2/9/2024 9:14:11 AM] MY20 Protection: Auto-Detect
[2/9/2024 9:14:11 AM] Formatting USB drive
[2/9/2024 9:14:11 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2/9/2024 9:14:20 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/9/2024 9:14:20 AM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[2/9/2024 9:14:20 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/9/2024 9:14:24 AM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[2/9/2024 9:14:24 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/9/2024 9:14:29 AM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[2/9/2024 9:14:29 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/9/2024 9:14:32 AM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[2/9/2024 9:14:32 AM] Preparing USB drive
[2/9/2024 9:14:32 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/9/2024 9:14:32 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/9/2024 9:14:32 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/9/2024 9:14:32 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/9/2024 9:14:32 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/9/2024 9:14:32 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/9/2024 9:14:43 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/9/2024 9:14:44 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/9/2024 9:14:44 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/9/2024 9:14:44 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/9/2024 9:15:02 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/9/2024 9:15:04 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/9/2024 9:15:04 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/9/2024 9:15:04 AM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/9/2024 9:15:32 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/9/2024 9:15:35 AM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/9/2024 9:15:35 AM] Generating Autoinstall.lst
[2/9/2024 9:15:35 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Run the Interrogator Utility in Syn3 Updater and post the results here, please.
Thank you. After trying one more thumb drive (Kingston - 16GB) it finally worked. I don’t know if it matters, but the thumb drive that worked was USB 2.0, whereas the three that didn’t were USB 3.0.
I do not even know what that is… but using a quality brand is always recommended, since the error you were facing could be due to a cheap/slow/unreliable device… As you said, it does not matter if it’s 2.0 or 3.0, it just need to be a good USB pendrive.
