Chimes sound
Is there a way to change the chimes on a 2015 F150 that has been retrofitted with a HD ACM from an Escape and switched from Sync2 to Sync 3, so that they sound as they did originally in an F150 when opening doors or seatbelts are reversed?
Old SYNC Version: 3.0.20220
New SYNC Version: 3.423188
no errors
The chimes should work thru the ACM if the ACM and APIM are properly configured. You might try performing a reset thru FORScan on the ACM. It will take an ignition cycle for the chimes to come back after that.
Oh the Chimes work but it sounds like a car not like a truck
Do you need a lower note?
Yes please
