I’m really hoping that I can get some help with this problem:
When I turn the ignition on, the clock changes to a random time. If I try to reset the time, it reverts back to the random time after a few seconds. As soon as the ignition is turned off, the clock returns to the correct time. (I have taken a video of this - https://youtu.be/jc3jxDTMK8M?si=vBrssD9zvpIRSAve
This is such a big problem for me as android auto will not connect whilst the clocks do not match the same time.
The car is a 2018 Ford Fiesta. Sync 3.3. Build 19052. Maps F12.
The only thing which may have caused this change was it had it’s MOT and service at a Ford Dealership, so potentially the APIM was changed?
I am quite a novice so any help will be appreciated.
So to add, a couple of years ago I upgraded to 3.4 which was perfect and I had no problems.
Since this issue started, I have downgraded back to 3.3 thinking this may have solved the issue, however this made no difference. My aim is to fix the clock and then upgrade again to 3.4.
I have master reset and soft reset but this has not made a difference.
The only ‘change’ would have been the service by Ford.
There is no real reason, just reading other forums it seems that this could be the issue, however I have just ran Forscan and the values are the same as factory so this seems unlikely.
This service by ford was the only thing that I could think could have caused this clock problem as I have not modified anything else within this period.
Your clock master is set to 6A=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3. This is not consistent with several asbuilts I looked at for North American 2017 thru 2019 Fiesta’s. Those all indicated A7=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA.
According to the Ford Master Clock documentation, Fiesta’s migrated to CGEA 1.3 in the 2017 model year, so the 6A setting would be correct.
Since your system has NAV, does it seem to operate correctly?
