Dead sync3
Hi friends I have switched from Sync2 to Sync3 and I wanted to hack the system to play me videos in the car. But i did something wrong and used what program reformat.After i installed reformat nothing goes. Black screen and no power going to the usb. This won’t even load the USB disc
When i put on back sync2 everything works.Is there any possibility to fix sync3 yet ?
I apologize in advance for the translation because I use translator.
Install Type: Unknown
Old SYNC Version: 23188
New SYNC Version: 23188
If you ONLY used reformat then you now need to install the SYNC software.
USB slot doesn’t work either
Can you share a picture of the Sync3 APIM 's back?, we are interested in the sticker…
A J series assembly from 2017?, sounds odd…
What do you think @bill32399 ?
Do you have Forscan and an adapter? Can you read the APIM 's model through Forscan?
Thank you for your willingness and I will find out the information tomorrow APIM
Thats a very early J series but most J series were in 2018 vehicles. You would usually find an H series in a 2016-2017.
I show a 2016 S-Max selling with Sync 3 not Sync 2.
Check the power supply circuit. The power supply line of SYN3 multimedia box is different. Need to convert the header.
Hi, Forscan sees a drive with data
Thank you for the information but the sync3 device and cable from sync2 probably doesn’t change anything significant. Because before I reformatted the system everything worked. Now the screen is black and no voltage goes to the USB. But as I wrote forscan can see the drive.
Hi, Forscan can see the data disk
Can you post a screenshot of what you are seeing on forscan?
It looks like it doesn’t have drivers
