THAIGHT91
(THAIGHT91)
October 3, 2023, 10:01pm
1
I ATTEMPTED TO UPDATE MY SYNC FROM 3.4 BUILD 22251 TO 3.4 BUILD 23188. I HAVE THE SMALL SCREEN, UPDATE COMPLETED SUCCESFULLY, BUT NOW THE APIM THINKS MY SCREEN IS 8" AND SHOWS ONLY THE TOP LEFT PORTION OF THE TOUCHSCREEN ON MY SMALL SCREEN. AM I SCREWED?
Old SYNC Version: 3.4.22251
Version: 3.4.22251
Region:
Model: PNY USB 3.2.1 FD USB Device
; CyanLabs Syn3Updater 2.12.2.0 Stable - Autoinstall Mode - Sync 3.4.23188 NA
FILES (4)
[9/28/2023 1:26:36 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[9/28/2023 1:26:36 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[9/28/2023 1:26:36 PM] MY20 Protection: Auto-Detect
[9/28/2023 1:26:36 PM] Formatting USB drive
[9/28/2023 1:26:36 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[9/28/2023 1:26:49 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/28/2023 1:26:49 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[9/28/2023 1:26:49 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/28/2023 1:26:52 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[9/28/2023 1:26:52 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/28/2023 1:26:55 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[9/28/2023 1:26:55 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[9/28/2023 1:27:01 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[9/28/2023 1:27:01 PM] Preparing USB drive
[9/28/2023 1:27:01 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/28/2023 1:27:01 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/28/2023 1:27:01 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/28/2023 1:27:01 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/28/2023 1:27:01 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/28/2023 1:27:01 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/28/2023 1:27:44 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/28/2023 1:27:56 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/28/2023 1:27:56 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/28/2023 1:27:56 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/28/2023 1:29:19 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/28/2023 1:29:37 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/28/2023 1:29:37 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[9/28/2023 1:29:37 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[9/28/2023 1:31:46 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[9/28/2023 1:32:13 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[9/28/2023 1:32:13 PM] Generating Autoinstall.lst
[9/28/2023 1:32:13 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
SaNdMaN
(SaNdMaN)
October 3, 2023, 11:48pm
2
Is your shift key stuck?.
If you have a 4 inches screen you can’t use Syn3updater since it will always use 8 inches packages. What you need to do is to manually create an autoinstall.lst file to install this package → 5U5T-14G381-FZ
That’s Sync3 v3.4.22110 for small screens.
That’s the latest build I can relate to 3.4 for small screens…
THAIGHT91
(THAIGHT91)
October 4, 2023, 2:09pm
3
Lol, No, I just write in all caps at work, and didn’t even notice.
So just copy that file to my usb and plug it in, and it should correct the issue?
As stated above, What you need to do is to manually create an autoinstall.lst file to install this package.
THAIGHT91
(THAIGHT91)
October 5, 2023, 12:38am
5
SaNdMaN:
autoinstall.lst
I get an lst_err when I plug it in. I have the autoinstall.lst in my root. What am I missing?
Just lst_err or did it have a number appended?
THAIGHT91
(THAIGHT91)
October 5, 2023, 12:26pm
7
Unfortunately because of the current issue I can’t see that portion of the screen. Only lst_er and then it cuts off
SaNdMaN
(SaNdMaN)
October 9, 2023, 11:10pm
9
I’m closing the thread since you went silent and did not provide the required information, so I’m assuming you lost interest on this or no more assistance is needed.
THAIGHT91
(THAIGHT91)
October 10, 2023, 9:27pm
11
Sandman, I apologize I didn’t respond in a timely manner on my previous post that you closed.
Here is the information that you requested.
err_lst
Version: 3.4.22251
Region:
FILES (4)
THAIGHT91
(THAIGHT91)
October 10, 2023, 9:30pm
12
SaNdMaN
(SaNdMaN)
October 10, 2023, 9:39pm
15
This is what I’ve asked:
SaNdMaN:
Provide:
the lst file you are using
a screenshot of your USB root’s contents
a screenshot of your SyncMyRider folder’s contents.
And you provided none of that…
THAIGHT91
(THAIGHT91)
October 10, 2023, 9:58pm
16
It’s all there in my replies?
SaNdMaN
(SaNdMaN)
October 10, 2023, 10:00pm
17
Nevermind, those messages now appeared…
Apologies, when I merged your threads and replied those messages were not displayed (or I didn’t see them).
Yes, that’s what I’ve asked, I will review them and will give you my findings.
SaNdMaN
(SaNdMaN)
October 10, 2023, 10:04pm
19
Well, that was quick… your lst file is pointing to 4U5T-14G381-AN_1552583626000.TAR.GZ, that’s wrong… you need to change all references to the small screen file, the one that’s under the SyncMyRide folder…
THAIGHT91
(THAIGHT91)
October 10, 2023, 10:34pm
20
To be honest, I’m uncertain where that lst file came from, or how to make the appropriate changes.
