What is your SYNC Region?
NA
What was your Old SYNC Version?
2.2.16280
Assuming a successful install failed; 2.2.16280
Do you have Navigation?
Yes
Yes. Red screen with a MEM_err003 as I recall, during initial install. No picture available.
CYANLABS - SYN3 UPDATER - V2.7.3.0
Operating System: Microsoft Windows 10 Home (1903)
Version: 2.2.16280
Install Mode: reformat
My20 Protection Enabled: False
FileSystem: FAT32
GRACENOTES=4U5T-14G423-CB_1598636132000.TAR.GZ
APPS=5U5T-14G381-EM_1611967752000.TAR.GZ
VOICE=5U5T-14G391-CN_1615429328000.TAR.GZ
; CyanLabs Syn3Updater 2.7.3.0 Stable - reformat Mode - Sync 3.4.20351 NA
FILES (4)
4U5T-14G423-CB_1598636132000.TAR.GZ (566.3MB)
5U5T-14G391-CN_1615429328000.TAR.GZ (385.4MB)
[6/5/2021 10:40:45 PM] Selected Region: NA - Release: Sync 3.4.20351 - Map Version: Non Nav APIM
[6/5/2021 10:40:45 PM] Install Mode: reformat Forced: False
[6/5/2021 10:40:45 PM] MY20 Protection: False
[6/5/2021 10:40:45 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[6/5/2021 10:40:45 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[6/5/2021 10:40:45 PM] Checking Existing File: 4U5T-14G423-CB_1598636132000.TAR.GZ
[6/5/2021 10:40:45 PM] Downloading: 4U5T-14G423-CB_1598636132000.TAR.GZ
[6/5/2021 10:42:02 PM] Validating: 4U5T-14G423-CB_1598636132000.TAR.GZ
[6/5/2021 10:42:06 PM] Downloaded: 4U5T-14G423-CB_1598636132000.TAR.GZ
[6/5/2021 10:42:06 PM] Checking Existing File: 5U5T-14G381-EM_1611967752000.TAR.GZ
[6/5/2021 10:42:06 PM] Downloading: 5U5T-14G381-EM_1611967752000.TAR.GZ
[6/5/2021 10:42:37 PM] Validating: 5U5T-14G381-EM_1611967752000.TAR.GZ
[6/5/2021 10:42:43 PM] Downloaded: 5U5T-14G381-EM_1611967752000.TAR.GZ
[6/5/2021 10:42:43 PM] Checking Existing File: 5U5T-14G391-CN_1615429328000.TAR.GZ
[6/5/2021 10:42:43 PM] Downloading: 5U5T-14G391-CN_1615429328000.TAR.GZ
[6/5/2021 10:43:03 PM] Validating: 5U5T-14G391-CN_1615429328000.TAR.GZ
[6/5/2021 10:43:06 PM] Downloaded: 5U5T-14G391-CN_1615429328000.TAR.GZ
[6/5/2021 10:43:06 PM] Preparing USB drive
[6/5/2021 10:43:06 PM] Formatting USB drive
[6/5/2021 10:43:06 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[6/5/2021 10:43:19 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[6/5/2021 10:43:19 PM] Copying: 1u5t-14g386-cb.tar.gz
[6/5/2021 10:43:20 PM] Validating: 1u5t-14g386-cb.tar.gz
[6/5/2021 10:43:20 PM] Copied: 1u5t-14g386-cb.tar.gz
[6/5/2021 10:43:20 PM] Checking Existing File: 4U5T-14G423-CB_1598636132000.TAR.GZ
[6/5/2021 10:43:20 PM] Copying: 4U5T-14G423-CB_1598636132000.TAR.GZ
[6/5/2021 10:45:15 PM] Validating: 4U5T-14G423-CB_1598636132000.TAR.GZ
[6/5/2021 10:45:19 PM] Copied: 4U5T-14G423-CB_1598636132000.TAR.GZ
[6/5/2021 10:45:19 PM] Checking Existing File: 5U5T-14G381-EM_1611967752000.TAR.GZ
[6/5/2021 10:45:19 PM] Copying: 5U5T-14G381-EM_1611967752000.TAR.GZ
[6/5/2021 10:48:19 PM] Validating: 5U5T-14G381-EM_1611967752000.TAR.GZ
[6/5/2021 10:48:33 PM] Copied: 5U5T-14G381-EM_1611967752000.TAR.GZ
[6/5/2021 10:48:33 PM] Checking Existing File: 5U5T-14G391-CN_1615429328000.TAR.GZ
[6/5/2021 10:48:33 PM] Copying: 5U5T-14G391-CN_1615429328000.TAR.GZ
[6/5/2021 10:49:56 PM] Validating: 5U5T-14G391-CN_1615429328000.TAR.GZ
[6/5/2021 10:49:58 PM] Copied: 5U5T-14G391-CN_1615429328000.TAR.GZ
[6/5/2021 10:49:58 PM] Generating reformat.lst
[6/5/2021 10:49:58 PM] Generating autoinstall.lst
[6/5/2021 10:49:58 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
PROBLEM: Using MS Windows Sync3 updater, files shown in the above log were saved to a formatted removable 32G USB 3.0 as preferred per instructions. Sync3 recognized the USB and initiated the update. About 15 minutes into the update I received a red screen with what I recall as a mem_err03 message following one of the TAR.GZ files (I can’t remember which one and did not take a picture at the time of the error message. Attempted to reinitiate the install but the system is stuck on the boot screen. After all attempted resets (Pwr + Skip/Ignition cycling/USB removal) a red screen message appears indicating “error update packages not found”
SOLUTION: Post on community forums and tag @CyanLabs for possible solution before spending the $399 for a new unit with Sync 3.0 installed. Wishful thinking…
UPDATE: System only cycles through mustang splash screens. Prompts to insert USB five seconds after startup, however, a red screen with “error update packages not found” is displayed the exact instant anything is inserted into the USB port. If USB is unplugged, system resets the splash screen loop.
