good afternoon I want to degrade and I can not, can you guide me where is the error.
es un apim sin Nav.
this is what it throws at me when checking memory
<d2p1:AdditionalAttributes logGeneratedDateTime=“2021-09-13T21:59:52+00:00” RAM=“417972224” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“465M” available=“3.1M”/>
<d2p1:PartitionHealth type="/fs/rwdata/" total=“1.2G” available=“1004M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“35M” available=“35M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“90M” available=“90M”/>
<d2p1:PartitionHealth type="/fs/mp/" total=“1.4G” available=“142M”/>
<d2p1:PartitionHealth type="/fs/images/" total=“3.0G” available=“2.4G”/>
What I can be doing wrong?
Are you trying to downgrade to version 3.4.19052?
Could you post the log file?
EDIT: I meant 3.3.19052, sorry…
I think he want’s to downgrade to 3.3 from 3.4.xxxxx.
@Diego_Hernan_Rimauro , post your logs please, and also the full interrogator log file (redact your VIN from the file name and content).
First of all, I would like to apologize for the message in private, it was just a mistake because I did not know how to create a thread. Then I publish the records
CYANLABS - SYN3 UPDATER - V2.10.3.0
Version: 3.4.20136
Region: ANZ
FileSystem: FAT32
; CyanLabs Syn3Updater 2.10.3.0 Stable - Autoinstall Mode - Sync 3.3.19052 ANZ
Item1 = APPS - 4U5T-14G381-AN_1552583626000.TAR.GZ
Item2 = VOICE - 4U5T-14G391-BJ_1552513817000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G391-BJ_1552513817000.TAR.GZ
Item3 = GRACENOTES - 4U5T-14G423-BA_123695.tar.gz
Open3 = SyncMyRide\4U5T-14G423-BA_123695.tar.gz
Another query, how long is the time it takes to install?
That part of the log seems ok, but it’s incomplete. I would assume that the validation and creation of the usb were ok, but I would like to see all the log.
Also, from that log, there’s something that should not be like that.
Check your USB in Windows, is it exFAT or FAT32 as the log says?.
And also, what issue are you having exactly?. It says “updating” but nothing happens?.
Process should last less than 30 minutes if the USB is good.
Have you tried a different USB stick?.
Please, create an Interrogator USB and post the log here (redact the VIn from the name and content of the file)
The updating poster stays and nothing happens
I don’t know if I understood what you asked me well, but I copy the data
Versión 5U5T-14G381-ED
Modelo de APIM: JR3T-14G371-BED
Tipo de APIM: Non-Navigation
Tamaño de APIM: 8GB
Espacio libre en APIM: 2.4G
14/9/2021 21:41:49 +00:00
Partition Type = Free / Total
/fs/Nuance/ = 3.1M / 465M
/fs/rwdata/ = 1010M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 142M / 1.4G
/fs/images/ = 2.4G / 3.0G
APIM AsBuilt
DE00: 036864929000CC110000
DE01: 415201064002080000000405
DE02: 0000010000
DE03: 01000B01000000
DE04: 17E8179828BE
DE05: 80
DE06: 0E033300000000135600000430580069
Looking at the autoinstall, you don’t have the space to process all 3 of the files to be installed at once. Only use the app file to perform the downgrade to 3.3.19052. Once that is done, then install the voice file separately.
The autoinstall for 3.3.19052:
Item1 = 4U5T-14G381-AN_1552583626000.TAR.GZ
Once this is done, install the voice file. The autoinstall:
[SYNCGen3.0]
Item1 = 4U5T-14G391-BJ_1552513817000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G391-BJ_1552513817000.TAR.GZ
Once this is done, run the Interrogator Tool to see if you have enough room for Gracenotes.
Perfect, this was the solution, now I could downgrade it and install the basic version 20351, now I have to follow the voice or the gracenotes to see if the space I have is enough, for which they recommend me
