Enabling Park Assist in Sync 3 (For those that have done a Sync 2 > Sync 3 Upgrade)
Mine does exactly the same after updating Sync 1 to Sync 3 in my 2014 Focus Titanium. Did you end up resolving this??
Sync 1? Did you mean Sync with My Ford?
Microsoft PowerPoint - SYNC Visual Reference Guide (ak-content-us-east-public.s3.amazonaws.com)
Original sync. When I did my conversion the tutorial was titled Sync 1 to Sync 3.
I don’t think I’ve heard of anyone getting this to work on a 2013-2016MY CMax/Focus/Escape/Kuga/MKC.
You’ll get the warning tones from the fore/aft sensors, but the parallel park function has been a no go.
My parking works perfectly it’s just the text on the screen has shifted left during the reversing like the original post I replied to.
2014 Escape TI with a MFT to Sync3 upgrade I was never able to get auto park assist back, still had a good working camera and backup lines.
The overhead graphic would not display, nor would the instructions when the button was pushed.
Another user not long ago on here had a 2013(?) MKC and never got it to work either.
I know Ford did make changes in the Escape after Job1 ended 11/2013, not sure about the Kuga.
The easiest way to tell if you have a pre-Job 2 is that you won’t have the digital speedometer available for the cluster center screen.
Hi, did you manage to make it work? how did you do? I have the same problem as you
Hello. Did you manage to solve the problem with the parking assistant screen moving from the reversing camera view for the changed Sync 2 to Sync 3 in Kuga?
I have a 2013 MKZ Hybrid that I replace MLT with SYNC 3 with Nav. I would like to re-enable the auto park assist and have tried to follow these directions. However, my PAM only has one line of As-Built data. Can this be done, then?
Thank you.
The 2013 for the Fusion/MKZ was a one off year.
Take a look over at 2gfusions.net, its more than likely that you’ll have to load a non-standard firmware built into the PAM.
Please help me. My active parking assist system shows ‘Not available’ after I updated Sync from 2.0 16074 to 3.3
Did you do a Master Reset?
Not yet.
I’m not sure how to do it. Please tell me.
Now I am trying to adjust the value through ForScan in APIM module.
I am not sure which Option to choose to be suitable for the car.
Focus Ecoboost 1.5L 2016 MK3.5 Sync 3
sorry I’m new to this world.
I’m writing to you because I see you’re an expert.
I have a 2020 Ford Fiesta MK8 I need to fit the front parking sensor kit (Ford code 2231907) and I would like to display the sensors on the sync3 display like the rear ones.
Please note the car has the sync2.5 as standard but in a few days I will fit the complete apim with the sync3 8 inches of the Ford Puma
scusami sono nuovo in questo mondo.
ti scrivo perchè vedo che sei esperto.
ho una ford fiesta mk8 2020 devo montare il kit sensori parcheggio anteriori (codice ford 2231907) è vorrei visualizzare i sensori sul display del sync3 come i posteriori.
nota bene l’auto ha il sync2,5 di serie ma io a giorni montero apim completo del sync3 8pollici della ford puma
Hello guys ,
First i wanted to say I found this entire thread extremely informative and useful , thank you for your hard work.
I hope you are able to help me as well
I have a ford edge sport 2016 which came with sync 2 And i just upgraded the module and the screen to sync 3 and noticed my flank guard isnt workin (does not show any color blocks) however I hear the beeps only while I am parking
Second thing is the auto parking doesn’t work i press the button but nothing comes up on the screen at all.
Note : both features worked perfectly before on sync 2 module
I don’t know if i should follow the same config mentioned in the thread for the asbuilt since its mentioned for ford focus
Please help me out any insight is highly appreciated
You can follow the procedure above, but don’t perform any firmware updates unless it does not work, as they should not be required in your vehicle. The adjustments should only really be needed in the APIM (Sync unit), so focus on those.
Svae your present settings first on any module you plan on changing. It’s a lot easier to load a file with the old settings rather than trying to remember what they were.
So I have a late 2015 early 2016 Ford Focus Mk3.5 that came with Sync 2. 12 Parking Sensors and the park assist button. I just made the upgrade to Sync 3 and running 3.4.23188 at the moment.
I did all the changes mentioned in here and also did my own research. The AsBuilt in the APIM and PAM were changed a couple days ago so I hoped it would catch itself. But at the moment I only get the HMI to show up when in reverse. Also the car doesn’t pick up anything from the front sensors.
I have not done the PAM firmware upgrade since reading the thread I was unsure If It has to be done or not. Most of the changes mentioned here match my old sync 2 asbuild settings. Other than what I had to change in the PAM for 736-03-01 XXXX-XX18-XX from 00 for the Sync 3 apim.
Hello. I know this is a very old thread I’m replying to, but I don’t see a lot of posts related to an issue I’m having, so hoping you can provide some help.
I have a 2014 Escape Titanium with rear parking aid sensors (so I got the green/yellow/red graphics when reversing with beeping if there’s an object, but no active-park-assist button). After upgrading from Sync 2 to Sync 3 (bought supposedly an OEM kit from eBay, provided my VIN to the seller, and it came pre-programmed), everything worked fine except I no longer get the green/yellow/red graphics and no beeping.
I’m trying to enable at least the beeping. I think I may need to try upgrading my PAM module, and if it doesn’t work, need to try swapping to a later year’s PAM module? But I can’t find any instructions on how I can upgrade my PAM module.
After some tinkering, I tried running all the vehicle tests using FORScan. One of the tests, I think for BdyCM (which honked and flashed various lights), resulted in “Parking aid fault Service required” flashing on that little screen between my speedometer and accelerometer. I’m assuming this must be related to why my parking aid is not working.
I had the same problem with my C-Max. I solved it by downloading the original AsBuild from Ford’s website. The color markers returned, and the automatic parking system started working. The only thing I couldn’t restore was the warning sounds for approaching obstacles. There’s a delay before the warning sounds only sound when the red area on the markers appears. Try the original AsBuild.
