Eroor log SYNC3 MY22
I have SYNC3 MY22
when load interogator log receive error
SYNC Region: Europe
Navigation Variant: Yes
Install Type: Unknown / Not Sure
Old SYNC Version: 3.4.22110
New SYNC Version: 3.4.22110
The XML file you have does not contain a valid ‘ECU Delivery Assembly Number’ therefore Sync Updater can not determine if this is a MY20+ APIM or not!’
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2022-06-22” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>WF0FXXWPMHNT…</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response5U5T-14G381-EZ</d2p1:Response>
</d2p1:DID>
d2p1:Response315535542d3134473432312d42414a000000000000000000315535542d3134473432312d42424a000000000000000000315535542d3134473432312d42434a000000000000000000315535542d3134473432312d42444a000000000000000000315535542d3134473432312d42454a000000000000000000315535542d3134473432312d42464a000000000000000000315535542d3134473432312d42474a000000000000000000315535542d3134473432312d42484a000000000000000000315535542d3134473432312d424a4a000000000000000000315535542d3134473635382d414800000000000000000000345535542d3134473432322d424247000000000000000000345535542d3134473432322d424447000000000000000000345535542d3134473432322d424347000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415300000000000000000000345535542d3134473432322d424147000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:Response315535542d3134473432342d424c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:ResponseN14601YP</d2p1:Response>
</d2p1:DID>
d2p1:Response00</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response94:a9:a8:14:6e:8d</d2p1:Response>
</d2p1:DID>
d2p1:Response94:a9:a8:14:6e:8e</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2022-06-22T13:39:30+00:00” RAM=“977084416” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.1G” available=“1.0M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.8G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.3G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“7.8M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.2G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.8G” available=“21M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“38M” available=“336K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.2G” available=“5.6M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.2G” available=“25M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.6G” available=“27M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.8G” available=“29M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.3G” available=“25M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“3.6G” available=“35M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“1003M” available=“21M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“971M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“72M” available=“332K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“54G” available=“11G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Syn3 Updater Version: 3.4.221000
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2022-06-22" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
  <p:VIN>WF0FXXWPMHNT.....</p:VIN>
  <p:RequestRole>
  </p:RequestRole>
    <d2p1:ECUAcronym name="APIM">
      <d2p1:State>
            <d2p1:Response>5U5T-14G381-EZ</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>315535542d3134473432312d42414a000000000000000000315535542d3134473432312d42424a000000000000000000315535542d3134473432312d42434a000000000000000000315535542d3134473432312d42444a000000000000000000315535542d3134473432312d42454a000000000000000000315535542d3134473432312d42464a000000000000000000315535542d3134473432312d42474a000000000000000000315535542d3134473432312d42484a000000000000000000315535542d3134473432312d424a4a000000000000000000315535542d3134473635382d414800000000000000000000345535542d3134473432322d424247000000000000000000345535542d3134473432322d424447000000000000000000345535542d3134473432322d424347000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415300000000000000000000345535542d3134473432322d424147000000000000000000</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>315535542d3134473432342d424c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>N14601YP</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>94:a9:a8:14:6e:8d</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>94:a9:a8:14:6e:8e</d2p1:Response>
          </d2p1:DID>
        </d2p1:Gateway>
      </d2p1:State>
    </d2p1:ECUAcronym>
    <d2p1:AdditionalAttributes logGeneratedDateTime="2022-06-22T13:39:30+00:00" RAM="977084416" vmcuVersion="Vector_VMCU_02.02.20">
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="1.0M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.8G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.3G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="7.8M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="17M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.8G" available="21M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="38M" available="336K"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="5.6M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="25M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.6G" available="27M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.8G" available="29M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.3G" available="25M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="3.6G" available="35M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/grace" total="1003M" available="21M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="971M"/>
      <d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
      <d2p1:PartitionHealth type="/fs/mp/resources" total="72M" available="332K"/>
      <d2p1:PartitionHealth type="/fs/images/" total="54G" available="11G"/>
      <d2p1:InstallationLog/>
      <d2p1:SyncData>MIIEdAYJKoZIhvcNAQcDoIIEZTCCBGECAQAxggG4MIIBtAIBADCBmzCBhjEbMBkGA1UEChMSRm9yZCBNb3RvciBDb21wYW55MQswCQYDVQQGEwJVUzERMA8GA1UEBxMIRGVhcmJvcm4xHjAcBgkqhkiG9w0BCQEWD21nbXNlY0Bmb3JkLmNvbTEnMCUGA1UEAxMeU3luYyBNb2R1bGUgRW5jcnlwdGlvbiBHZW4zIEEyAhDfwyMpAoa+v0vYmqleqJR7MA0GCSqGSIb3DQEBAQUABIIBAGk9B1IZxtubgl2Mb2YTfbFDGsWJqH7vqWAgQxks6udhLfK4NDCkbrni4sCFAYZOGk9giGX5wtjo3NP6Wb/OsRZIR5yw2AHF208CHNfFInXKrxSlCgybg8/DacoejojyXWRCgdUSoVYCeQlcqnIn6fI24V/gQR/u8i1CDlV07fXAbRNumoHlVYpNr4VakumDI0JTHQvocrtzFnYvO+qzCfENgG7rh5IL5OPGdKG6qMYDUDX69rHHymHUZeyjAu4tdPQzMR5s8V0gEEJC8eZ4WPfspfeyu5eYJdxPps/iYWj/I6pi0DPdqOINUVkLh4pR1wtT6X/7EgcVdGKEu7EkpF8wggKeBgkqhkiG9w0BBwEwHQYJYIZIAWUDBAEqBBCQaLSsNxn/RuB9bUmizacSgIICcIh0a/NS7bqGZyJRl9oVtWOk2/5yn60c1MDI1gI1ZUiJB0nWCmzr51Vp/AMOGosJLKeTV4C3F/QFdnkBtzbqp1wUhW5mpWOqe6XH8jeZGjNEk4Ehp3uk3jhYBRE8uCRwt6U1WqLpAgnOfb+2lFaVHJnos4W1eHCm0tY79MRQy4mW3cXfxIYttZxlWZURXSDdVGXYd0IOkPO5AksiJZ7GHxWs40nMc3FAMQ8n6qsvHHQnCXRaEypsYx77pACQJczhg1hwUl6T8Rht7FVTpcFzVNDW9skdhSWkpKX/askV08WJmspVsKw/e1/67vwHCC7tX8rugrhDfkkX/vdCA800yGdj35Nw21kT/i1LXYThJ9I7Jqa7HvhoI+TkQvGJVnsWkKUTslIKK3obrJC1TgooDuzQKK0wI1CUHeCPn1iP/7tiTXqPjUX3p/NZqha03P8aTlnykOQ92iqB14NTwjKWn1p+tNPymOhoNjC+yPvp4kmhM+IAe8WCCb2b2gpu0fquDCzARBzH9q3fLB7t0LIOiFrcrEV/er+imjHKbncWnAN9i9/zY7kG4Lavrc8Uqkyrfg5t+YcmcEE/rOxNcb+OF0hCFbtFYHmM64bdrGospijwvlc8sPUNcdblEqAVgswBAsTrcQGWnZqouqQVzzr9JkrfxYxri/dpcyeGpMWfvOrkNCoWYMoRIT7xrC3JmCZe6gVcT05ujGLOs4LHWejc6XJ/P0bIMB64RtpR0pMW/2t+Hufd+yWZmDKRGhb3oEP7NFLnoXfuaEg22WChWet/jx26jPnJ4FZlKPN8azFtzZljFRbUICh8mF6xIjFo0+2pig==</d2p1:SyncData>
  </p:Node>
Hello.
Is there a question?.
Error is quite self-explanatory: the interrogator tool can’t determine your APIM’s model.
