666999
(666 999)
1
ERROR IN 4U5T-14G421-CCE-1644007833000.TAR.G2
Navigation Variant: No
Install Type: OEM Replacement
Old SYNC Version: 3.0.20204
New SYNC Version: 3.4.20220
Syn3 Updater Version:
F150Chief
(F150Chief)
2
This is a map file and you have a NON-NAV APIM…can’t install maps on this APIM.
(666 999)
3
How can I go back and start over?
F150Chief
(F150Chief)
4
Use the Syn3 Updater and select NO navigation in the vehicle setup page. Then proceed from there. It will not load the maps.
Post the installation log file.
F150Chief
(F150Chief)
7
Is this the new setup? Or the one that had the error?
F150Chief
(F150Chief)
9
Honestly, do yourself a favor and update to 3.4.21265. The newer releases have issues with clock settings for NON-NAV units.
(666 999)
11
Is it normal for it to stay like this?
(666 999)
12
I already downloaded the version that tells me, connect the usb to the car again but it just stays that way and time is the only thing that advances
bill32399
(bill32399)
13
It is not normal, Start over and try the other USB port.
(666 999)
14
when I turn on the car the screen appears like this, when i connected the usb only “starting update” appears but the green line does not advance
bill32399
(bill32399)
15
It is stuck than. Try unplugging the car from the battery for a few minutes.
666999
(666 999)
16
is solved. thank you very much for your help
CyanLabs
(CyanLabs)
17
Please post 1 message don’t spam us with many replies, there is a EDIT button.
We are all volunteers be patient!
