Error Code:SIGN_ERR01 when attempting SYNC3 Build 20204 NAV update, 2020 NA2.20 Map Installation
I used the Syn3 Updater to create an Interrogator Log USB. This formats the disk and installs the interrogator tool. I did this before deleting the files and copying over files for the Sync and then NAV update (as shown in my previous reply).
I went ahead and repeated this to have a fresh disk and generate a new interrogator log output. Please see screenshot of the interrogator log output as well as copied information from middle column as it wouldn’t all fit in a screenshot. This is my current setup with updated Sync, SystemVoice and Gracenote from the tutorial.
Partition Type = Free / Total
/fs/usb0/ = 58G / 58G
/fs/tmpfs/ = 123M / 128M
/fs/sd/MAP/ = 635M / 12G
/fs/Nuance/ = 230M / 4.6G
/fs/Nuance/ = 2.5M / 482M
/fs/Nuance/grace = 5.1M / 1.0G
/fs/rwdata/ = 638M / 1024M
/fs/mp/ = 40M / 1024M
/fs/images/ = 6.8G / 26G
Installed Packages
GB5T-14G421-CJ
GB5T-14G424-CH
JR3T-14G391-CE
GB5T-14G422-CJ
JR3T-14G423-CB
I tried to do the update once again using a different USB Drive, 32GB Sandisk USB3.0, still no luck. I get the update screen prompt, I select update. I immediately get the SIGN_ERR01 error.
Everything works on my system, just wanting to get updated maps loaded.
