Error installing Sync 3.4
Hi guys,
I have a Ford which I have purchased not long ago and the Sync felt very slow, it is/was version 2.3.17109 and does not have Sat Nav. First time Ford owner and I have been trying to update the Sync to 3.4 with Sat Nav, hoping I can get a more smoother Sync with Sat Nav so I don’t have to use my phone.
I have tried 3 times to install via a USB and keep getting the message below, i assume this is an error with a particular file. I am currently in the process of creating the USB again and will try to install again.
“Error in 1U5T-14G421-BEL_1723601194000.TAR.GZ :”
Currently though, my screen is stuck on the insert USB screen to update the Sync. If the installation does not work is it possible to go back to the version I was using? If so, how do i go about doing that?
I cannot provide a log file for the installations I have tried and I deleted all the content of the USB and currently downloading again.
Any help would be greatly appreciated, thank you in advance.
Old SYNC Version: 2.3.17109
No log file.
you can’t put maps on a non nav, you don’t have enough storage space
Do I need a new unit for the sat nav or can i upgrade the storage?
Is that the reason for my error? Running out of storage during installation?
Hello.
You need to replace the APIM with a 64GB one.
Yep, that’s already been answered :point_down:
