tomtel
(tomtel)
9 December 2020 15:33
1
Tries to see what’s on the APIM interface and the disk space and file structure with GB5T-14G386-AC_1587495565000.TAR. GZ.
I prepared a USB to which I uploaded the file to the ‘SyncMyRide’ directory and placed the DONTINDX.MSA file and created the autoinstall.lst file
Item1 = GB5T-14G386-AC_1587495565000.TAR.GZ
Open1 = SyncMyRide \ GB5T-14G386-AC_1587495565000.TAR.GZ
When trying to read from APIM, it throws “LST ERR07” error. What could be the reason for this?
CyanLabs
(CyanLabs)
9 December 2020 16:17
2
LST_ERR07 – Error is LST_ERR_NO_OPEN1_PARAM
The autoinstall.lst should be in the root of the USB drive not the SyncMyRide folder
tomtel
(tomtel)
9 December 2020 16:37
3
this is
SyncMyRide/GB5T-14G386-AC_1587495565000.TAR
DONTINDX.MSA
autoinstall.lst
F150Chief
(F150Chief)
9 December 2020 18:39
4
You have spaces in your commands…use this.
Open1 = SyncMyRide\GB5T-14G386-AC_1587495565000.TAR.GZ
tomtel
(tomtel)
9 December 2020 22:57
5
Unfortunately it did not help, could it be the fault of a damaged GB5T-14G386-AC_1587495565000.TAR.GZ file?
Where can I download a good, tested file?
F150Chief
(F150Chief)
9 December 2020 23:07
6
GB5T-14G386-AC 43.07 KB ALL utloggingutility 1D8A92F839324C96C7A9AD95A2AFC39E
Do not unzip any files.
You can go here and download the files and transfer directly to the usb…
https://drive.google.com/drive/folders/1J2wUtMmH1xEnu0EOlBOLysCAL1u3YoME?usp=sharing
tomtel
(tomtel)
10 December 2020 08:53
7
Everything worked fine. Thanks a lot!
I received the file Sync_WY886W02_2FMPK4AP5KBC*****.xml
What’s the best way to open this file for viewing?
tomtel
(tomtel)
10 December 2020 09:43
8
It opens to me like this. Correct?
How to read this file. I need information on how much space I have left (which regions of the map can still fit). As far as I know, there must be 2-4GB free to be able to carry out another update (change).
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2020-12-10" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>2FMPK4AP5KBC*****</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>5U5T-14G381-EG</d2p1:Response>
</d2p1:DID>
<d2p1:Response>355535542d3134473339312d414d00000000000000000000345535542d3134473432332d414200000000000000000000315535542d3134473635382d414600000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>1f1dd7c4</d2p1:Response>
</d2p1:DID>
<d2p1:Response>135d1a7d</d2p1:Response>
</d2p1:DID>
<d2p1:Response>aa2a010304022b00068a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>504c0b04e40340900080c005</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0000010200</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01000300090007</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1ba31b9b2bc5</d2p1:Response>
</d2p1:DID>
<d2p1:Response>90</d2p1:Response>
</d2p1:DID>
<d2p1:Response>08003300000000186a00005656860070</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-1U5T-14G371-DA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1U5T-14G380-EE</d2p1:Response>
</d2p1:DID>
<d2p1:Response>4U5T-14G371-CJA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1U5T-14G375-DA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>WY886W02</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>1U5T-14G374-DA</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>38:81:d7:9e:5a:15</d2p1:Response>
</d2p1:DID>
<d2p1:Response>38:81:d7:9e:5a:16</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2020-12-10T09:44:04+00:00" RAM="1098747904" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="676K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="8.4M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.6G" available="29M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.6G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="3.4G" available="33M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="998M" available="21M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="971M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="128M"/>
<d2p1:PartitionHealth type="/fs/mp/resources" total="73M" available="432K"/>
<d2p1:PartitionHealth type="/fs/images/" total="25G" available="4.9G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
tomtel
(tomtel)
10 December 2020 11:48
9
<d2p1:AdditionalAttributes logGeneratedDateTime=“2020-12-10T09:44:04+00:00” RAM=“1098747904” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.1G” available=“676K”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“3.2G” available=“8.4M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“3.6G” available=“29M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“4.6G” available=“27M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“3.4G” available=“33M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total=“998M” available=“21M”/>
<d2p1:PartitionHealth type="/fs/rwdata/" total=“1.2G” available=“971M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“35M” available=“35M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“90M” available=“90M”/>
<d2p1:PartitionHealth type="/fs/mp/" total=“1.4G” available=“128M”/>
<d2p1:PartitionHealth type="/fs/mp/resources" total=“73M” available=“432K”/>
<d2p1:PartitionHealth type="/fs/images/" total=“25G” available=“4.9G”/>
I can see that this is the most important part. Can you learn more from this file?
I have 3 map packages installed and 4.9GB is free
How many can I pack to fill the memory, how much must be left?
Thank you for all your help
F150Chief
(F150Chief)
10 December 2020 20:22
10
You have 4.9GB of space left on the unit. You must leave about 1.5GB for the unit to function and for updates. Therefore, you have about 3.4GB of free space available to use for maps if you like. Remember, the size stated for the map file is compressed size, they expand about 1.5 times, roughly. I think you can use like 2 each 1GB files or a 2GB file, or combination like that.
Other things in the file:
This is your APIM As Built data, without parity values.
d2p1:Response aa2a010304022b00068a</d2p1:Response>
d2p1:IsConfig true</d2p1:IsConfig>
</d2p1:DID>
d2p1:Response 504c0b04e40340900080c005</d2p1:Response>
</d2p1:DID>
d2p1:Response 0000010200</d2p1:Response>
</d2p1:DID>
d2p1:Response 01000300090007</d2p1:Response>
</d2p1:DID>
d2p1:Response 1ba31b9b2bc5</d2p1:Response>
</d2p1:DID>
d2p1:Response 90</d2p1:Response>
</d2p1:DID>
d2p1:Response 08003300000000186a00005656860070</d2p1:Response>
ECU Calibration Data #1 Number (Calibration)
1U5T-14G375-DA
Vehicle Manufacturer ECU Software Number (Strategy)
1U5T-14G374-DA
Private Sub Node #1 Serial Number (Sync Serial Number)
WY886W02
ECU Delivery Assembly Number (Sync Assembly Part Number)
4U5T-14G371-CJA
Embedded Consumer Operating System Part Number (Sync App Version)
5U5T-14G381-EG
tomtel
(tomtel)
10 December 2020 21:15
11
Thanks again
My knowledge is much greater now. I was able to reprogram the Sync3 units from US to EU.
I will continue to try to change and improve Sync3.
Thanks for your input, database and help
