Error PKG_ERR04 and English voice Language Problem
Hi, I just updated APIM from US 3.0.17276 to EU 3.4.23188 and F12 Maps, I used your tool.
The update completed with an error,
Every time the device is started, the message is displayed, I changed the flash drive, but the update failed to continue.
APIM works fine and European maps also work fine.
Another problem is that the device started speaking in French when the English language was selected.
Can you help me to clear the errors?
These are the logs I can provide.
AS BUILD LOG
VIN: MAJ6S3JL0KC286051
Version NU5T-14G381-AD
APIM Model: JK2T-14G371-CCC
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 7.6G
30.5.2024 г. 18:14:26 ч. +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 804K / 1.2G
/fs/sd/MAP/ = 21M / 3.8G
/fs/sd/MAP/ = 26M / 3.2G
/fs/Nuance/ = 29M / 5.0G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 953M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 7.6G / 25G
Installed Packages
1U5T-14G421-BAK
1U5T-14G421-BBK
1U5T-14G421-BHK
5U5T-14G391-AT
4U5T-14G422-BAK
4U5T-14G423-AC
1U5T-14G658-AH
APIM AsBuilt
DE00: 2A2A010640022A06008A
DE01: 55530104C082019028804005
DE02: 0000010200
DE03: 00000082070001
DE04: 1900190026AC
DE05: 80
DE06: 0E04330000000080E80000565664006B
Old SYNC Version: 3.0.17276
Instalation failed
Error Code PKG_ERR04
Operating System: Microsoft Windows 7 Enterprise  ()
Version: 3.0.17276
Mode: Directory
Path: C:\Users\T530\Desktop\USB-2024\
MAP=1U5T-14G421-BAK_1682464992000.TAR.GZ
MAP=1U5T-14G421-BBK_1682466740000.TAR.GZ
MAP=1U5T-14G421-BHK_1682468092000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAK_1682464728000.TAR.GZ
; CyanLabs Syn3Updater 2.12.5.0 Stable - reformat  Mode - Sync 3.4.23188 EU
FILES (10)
1u5t-14g386-cb.tar.gz (8,5MB)
1U5T-14G421-BAK_1682464992000.TAR.GZ (2,3GB)
1U5T-14G421-BBK_1682466740000.TAR.GZ (541,8MB)
1U5T-14G421-BHK_1682468092000.TAR.GZ (2,7GB)
4U5T-14G422-BAK_1682464728000.TAR.GZ (2,3GB)
Why are you overriding the install mode?
Also What is your Current SYNC version?
Not sure where overriding the install mode came from
Current SYNC Version is 3.4.23188
Syn3 Updater is not configured correctly, correct your Current Version in the app.
Version: 3.4.23188
Install Mode Overridden: True
Mode: Directory
Path: C:\Users\T530\Desktop\rapair USB\
; CyanLabs Syn3Updater 2.12.5.0 Stable - reformat FORCED Mode - Sync 3.4.23188 EU
FILES (4)
[31.5.2024 г. 15:15:44 ч.] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: Keep Existing Maps
[31.5.2024 г. 15:15:44 ч.] Install Mode: reformat (reformat) Forced: True
[31.5.2024 г. 15:15:44 ч.] MY20 Protection: Disabled / Not MY20
[31.5.2024 г. 15:15:44 ч.] Clearing Selected Folder
[31.5.2024 г. 15:15:44 ч.] Checking Existing File: 1u5t-14g386-cb.tar.gz
[31.5.2024 г. 15:15:44 ч.] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[31.5.2024 г. 15:15:44 ч.] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 15:15:44 ч.] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[31.5.2024 г. 15:15:44 ч.] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 15:15:53 ч.] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[31.5.2024 г. 15:15:53 ч.] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 15:15:59 ч.] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[31.5.2024 г. 15:15:59 ч.] Preparing selected directory (No USB Drive Selected)
[31.5.2024 г. 15:15:59 ч.] Checking Existing File: 1u5t-14g386-cb.tar.gz
[31.5.2024 г. 15:15:59 ч.] Copying: 1u5t-14g386-cb.tar.gz
[31.5.2024 г. 15:15:59 ч.] Validating: 1u5t-14g386-cb.tar.gz
[31.5.2024 г. 15:15:59 ч.] Copied: 1u5t-14g386-cb.tar.gz
[31.5.2024 г. 15:15:59 ч.] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 15:15:59 ч.] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 15:15:59 ч.] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 15:15:59 ч.] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 15:15:59 ч.] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 15:15:59 ч.] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 15:16:01 ч.] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 15:16:08 ч.] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 15:16:08 ч.] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 15:16:08 ч.] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 15:16:09 ч.] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 15:16:13 ч.] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 15:16:13 ч.] Generating reformat.lst
[31.5.2024 г. 15:16:13 ч.] Generating autoinstall.lst
[31.5.2024 г. 15:16:13 ч.] ALL FILES DOWNLOADED AND COPIED TO THE SELECTED FOLDER SUCCESSFULLY!
So is it correct to update without the maps without GRACENOTES and without ENH-DAB
Shows a 32GB APIM, EU should be a 64GB.
I’m assuming you used a cut down map package?
i usw only this packs
with the maps there is no problem
still overriding the install mode for somereason
Finally I think I did it, please confirm the logs before I go to the vehicle.
Thanks for your time and advice.
Version: 3.4.23188
Region:
Mode: Directory
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall Mode - Sync 3.4.23188 EU
Item2 = VOICE - 5U5T-14G391-AT_1660763323000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-AT_1660763323000.TAR.GZ
Item3 = APPS - NU5T-14G381-AD_1689364279000.TAR.GZ
Open3 = SyncMyRide\NU5T-14G381-AD_1689364279000.TAR.GZ
FILES (3)
[31.5.2024 г. 16:49:48 ч.] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: Keep Existing Maps
[31.5.2024 г. 16:49:48 ч.] Install Mode: Auto-Detect (autoinstall) Forced: False
[31.5.2024 г. 16:49:48 ч.] MY20 Protection: Auto-Detect
[31.5.2024 г. 16:49:48 ч.] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 16:49:48 ч.] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[31.5.2024 г. 16:49:48 ч.] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 16:50:03 ч.] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[31.5.2024 г. 16:50:03 ч.] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 16:50:12 ч.] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[31.5.2024 г. 16:50:12 ч.] Preparing selected directory (No USB Drive Selected)
[31.5.2024 г. 16:50:12 ч.] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 16:50:12 ч.] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 16:50:12 ч.] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 16:50:12 ч.] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[31.5.2024 г. 16:50:12 ч.] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 16:50:12 ч.] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 16:50:19 ч.] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 16:50:35 ч.] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[31.5.2024 г. 16:50:35 ч.] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 16:50:35 ч.] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 16:50:40 ч.] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 16:50:50 ч.] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[31.5.2024 г. 16:50:50 ч.] Generating Autoinstall.lst
[31.5.2024 г. 16:50:50 ч.] ALL FILES DOWNLOADED AND COPIED TO THE SELECTED FOLDER SUCCESSFULLY!
