I updated My Sync 3 from 3.0.19205 to 3.4.21265 with F10 maps using Syn3 Updater 2.10.6.0. The update was successful. I then created an Interrogator Log USB and inserted it into the car. Sync 3 responds with “Installation Failed - Error Code PKG_ERR04”. How can I solve this?
The USB drive contents look like:
PS E:\> tree /f
Folder PATH listing for volume New Volume
Volume serial number is 1E94-4724
E:.
│ autoinstall.lst
│ DONTINDX.MSA
└───SyncMyRide
GB5T-14G386-AB_134244.tar.gz
You have AB interrogator tool, if you are on 21265 you need AD, update SYN3 Updater to have the correct current version then recreate your interrogator USB
I see, makes sense. And I tried that too, and should have mentioned that immediately.
When I set the version to 3.4.21265 and try to create the interrogator USB it will try to download stuff and I see a red box saying: “ERROR The remote server returned an error: (409) Conflict.”
The log says:
[2021-12-12 10:50:12] Selected Region: - Release: Interrogator Log Utility - Map Version:
[2021-12-12 10:50:12] Install Mode: Auto-Detect (autoinstall) Forced: False
[2021-12-12 10:50:12] MY20 Protection: Auto-Detect
[2021-12-12 10:50:12] Formatting USB drive
[2021-12-12 10:50:12] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2021-12-12 10:50:17] Checking Existing File: GB5T-14G386-AD_1606255780000.TAR.GZ
[2021-12-12 10:50:17] Downloading: GB5T-14G386-AD_1606255780000.TAR.GZ
Via Wireshark I see that eventually a connection is made to ivsubinaries.azureedge.net while trying to download (it’s all HTTPS, so I can’t see the actual HTTP request). Is this the issue: “Ford are currently blocking direct IVSU downloads!”? If so, can I download the file anywhere else and create the USB manually?
Hello, just went to the original sync3 update page and entered a chassis number there and there I am offered an update. So the update function works. Since I work at Ford, I would not have known that Ford is blocking any routes. Please admin controls this please.
Greetings Ralf
Unfortunately, I have to agree with you, have now tried several chassis numbers, neither sync update nor map update work. Starts briefly and then breaks off
