Error PKG_ERR04 with Interrogator
I see, makes sense. And I tried that too, and should have mentioned that immediately.
When I set the version to 3.4.21265 and try to create the interrogator USB it will try to download stuff and I see a red box saying: “ERROR The remote server returned an error: (409) Conflict.”
The log says:
[2021-12-12 10:50:12] Selected Region:  - Release: Interrogator Log Utility - Map Version:
[2021-12-12 10:50:12] Install Mode: Auto-Detect (autoinstall) Forced: False
[2021-12-12 10:50:12] MY20 Protection: Auto-Detect
[2021-12-12 10:50:12] Formatting USB drive
[2021-12-12 10:50:12] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2021-12-12 10:50:17] Checking Existing File: GB5T-14G386-AD_1606255780000.TAR.GZ
[2021-12-12 10:50:17] Downloading: GB5T-14G386-AD_1606255780000.TAR.GZ
Via Wireshark I see that eventually a connection is made to ivsubinaries.azureedge.net while trying to download (it’s all HTTPS, so I can’t see the actual HTTP request). Is this the issue: “Ford are currently blocking direct IVSU downloads!”? If so, can I download the file anywhere else and create the USB manually?
