today i started the upgrade from 3.0 to 3.4 but it seems to be it doesn’t work → Update packages not found with a red screen and no way back to the current version is possible. i had chosen the manual variant. now i am trying the automatic variant. do i have to put all these files manualy to the usb stick and creating an autoinstall.lst. i am a little bit confused now thanks for help
Hi first have message in red screen ERROR UPDATE PACKAGES NOT FOUND…
When i remove or put in back the USB drive, i see the “mustang” screen with message “starting update”
There is an issue with reading the USB or your file structure is not correct. The system cannot find your update files which should be in the SyncMyRide directory on the USB.
Please post your log file if you are using the Syn3 Updater.
