What is your SYNC Region? EU
What is your current SYNC Version? 3.3.30351
Do you have Navigation? Y
Do you have a error message, if so what is it? mem-err001
<d2p1:AdditionalAttributes logGeneratedDateTime="2021-04-02T11:49:58+00:00" RAM="1039380480" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="676K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.7G" available="16M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.4G" available="16M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="9.3M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="18M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.7G" available="24M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="38M" available="308K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="8.4M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.6G" available="29M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.4G" available="26M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.6G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.1G" available="24M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="3.4G" available="33M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.9G" available="8.5M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="59M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="950M"/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total="35M" available="30M"/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total="90M" available="82M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="128M"/>
<d2p1:PartitionHealth type="/fs/mp/resources" total="73M" available="432K"/>
<d2p1:PartitionHealth type="/fs/images/" total="54G" available="12G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
… Get MEM-ERR001 when trying to install new maps F10
