F150 Raptor 2018 from US to EU Navi
As it is a non EU car you won’t have it.
Have you changed your region to a DAB region in the ACM? You need both ACM and APIM.
For the ACM, 727-04-01 xxxx xx** **xx Country Code: 5553=U.S.
You need where you are that has DAB. See the APIM Database under the region tab on this site.
Again you can not get DAB working on a US ACM! This is not possible, we use completely different hardware, DAB is not even satelite based
DAB digital radio is a terrestrial-based system, which means the services are broadcast on a number of multiplexes across the country with capacity for a certain number of services. These multiplexes are broadcast in different areas/regions via many transmitters across the UK. For DAB, the selection of stations you receive will depend on where you live.
You’re right, missed that…
Any recommendations what part numbers to get to get all the euro stuff working?
