Fiesta Type JHH 1,0 Ecoboost Vignale Update of Sync
Hi community. I’ve bought above Fiesta for my daughter. The Syncversion is 3.0 Build 23219_PRODUCT
I prepared an interrogator stick and found the model-no: JK2T-14G371-FCC
Is it possible to update it to latest v3.4?
Regards Ludger
Old SYNC Version: 3.0.23219
New SYNC Version: 3.0.23219
As long as it is not a 2020+ APIM you are fine. Based on that model number and the database here than you should be good. Personally I perfer to look at the sticker just to be safe.
Thks. With Sticker do you mean the serial label on the unit? If yes - where ist this part?
Regards Ludger
Keep in mind that for your vehicle the only difference between 3.0.23219 & 3.4.232188 is a prettier interface, the two builds were released just slightly over a month apart.
Any thing additional that you might want to try to turn on the 3.4.x gives you requires updating the APIM firmware/calibration as well.
Build date is the most important but not 100% as some late 2019 manufature dates were 2020+ APIMS.
