Yes, but since your region seems to be ANZ, you will need to perform a reformat again because you cannot update ANZ maps only since they are locked.
The app will show information based on how you configured it; the app does not know what your car is or what it has, it’s up to the user to properly configure it.
I think Carplay does not work with IPC, and I have my doubts about Android.
Possibly, I do not recall what the default is.
But again, it’s up to the user to configure the app (region, current version and if the unit has NAV).
Once you “unlock” that, it will enable you to select maps when creating a new upgrade USB.
