Hello. I bought Edge 2016 with sync 3 from USA but non-navi. I connected Sync 3 64GB from Kuga 2022. I have problem with navigation, just i turn left or right but navigation showing like i am going straight. Original antena stays from previous sync with compass. After few seconds back to correct position and again problem with localization.
I didn’t check with original Sync version from Kuga, just connect and put USB with updade.
2nd question, can i use sync updater with auto-detect to downgrade sync from 3.4.22251 to 3.4.21265? and later update maps from f10 to f11? i am worry because its MY20+
Old SYNC Version: 3.4.20021
New SYNC Version: 3.4.22251
Syn3 Updater Version: 2.1.1.8.0
don't have yet
Yes, make sure to use the “autoinstall” option only.
Note: The maps upgrade from F10 to F11 will take about 90 minutes using autoinstall.
As far as the navigation, I’ll assume you already have F10 maps in EU and you probably do not have a GPS lock.
There may be a red circle with a bar thru it on the nav screen?
Also, did you transfer the asbuilt vehicle values from 7D0-07-xx to the new APIM?
Maps update done. With autoinstall can’t do, not enough space - free ~12gb, maps f11 ~22gb on usb. But I used maps removed from fmods and later transfer f11 maps to sync 3. Everything work, but problem with gps still exist. I can found all satelites, I have correct position on Navi screen, but problem starting when I try drive straight or turning left or right.
I didn’t transfer Apim configuration, because Ori Apim already “bricked”. Unfortunately when I tried update to MY18 something goes wrong. Old Apim was non Navi. I keep old antena for Sirius/GPS.
Message me your VIN.
Your asbuilt is not correct for your vehicle, as it is still unmodified from the Kuga…
Do you have FORScan or UCDS and an OBD adapter?
Can you post the asbuilt from the Kuga APIM?
What country are you in?
If so. then proceed with this below…
2FMPK4AP7GBC05380
2016 Ford Edge
Original asbuilt, NON-NAV:
7D0-01-01 AA2A 0503 00B5
7D0-01-02 008B 0006 80EB
7D0-02-01 5553 0104 C047
7D0-02-02 0240 8000 009D
7D0-02-03 0000 DC
7D0-03-01 0000 0002 00DD
7D0-04-01 0100 0300 00E0
7D0-04-02 0001 DE
7D0-05-01 1BA3 1B9B 2B7C
7D0-05-02 C5A3
7D0-06-01 805E
7D0-07-01 0800 3300 001A
7D0-07-02 0000 186A 0062
7D0-07-03 0056 5686 0013
7D0-07-04 7052
7D0-08-01 0000 0000 00E0
7D0-08-02 0000 0000 00E1
Convert to NAV: (Load this entire asbuilt with FORScan.)
7D0-01-02 028B 0006 80ED
7D0-02-01 xxxx 0104 C047
7D0-02-03 0000 DC
7D0-04-02 0001 DE
7D0-05-02 C5A3
7D0-06-01 805E
7D0-07-04 7052
xxxx = Insert your country code here.
Yes, forscan. Now I know what’s wrong. I don’t have this car right now, it’s my friend car. I am from Poland so the code is 504C. If my friend comes to my I will reply Kuga as built
Thank you very much
