Ford Ranger 2016 sync 3 update maps issue (map update stop in a specific point)
Hello to everyone. I’ve got a Ford Ranger 2016 with sync 3 and software version 2.0. I tried to install the F12 maps version via USB. Firstly I received a red screen with the message “Error in NU5T-14G381-AD_1689364279000.TAR.GZ”. I remove the USB and I downloaded again and copy the specific file to the USB again. The install move forward to the green bar but the map update stops to “Extracting map package”. I tried to reset the screen using the two buttons (on/off and >>) the screen restarts but has stuck to the same point (extracting map package). When I remove the USB the installs green bar starts from the begin and shows me a message “Please insert USB stick”. Is there any way to abort the install and go back to the initial condition or fix the problem? Thank you in advance
Old SYNC Version: 2.0
New SYNC Version: 2.0
As yours is a pre-MY20 why not go the whole hog and do a reformat install with latest software and maps.
You say it’s a 2016 but your profile says 2015. Which one is it?
2015 appears to come with Sync 2 so this must be a retrofit? Or is it a 2016 which shows it came with Sync 3?
The correct year could help troubleshoot this.
Hello again. I found some corrupted files in my USB stick. I replaced it and I start over the install. It works fine now. Thank you for your support.
