hello,
i have a problem updating from 3.4-build 19278 to 3.4 - build 20282
everything works fine…just the waze speedometer stopped showing speed. It shows it when i unplug the usb cable from the car.
any known trouble here ?
thank you,
jure
hello,
thank you,
jure
Nothing to do with this, Waze stopped it working, there is a known issue for it and Waze aren’t doing anything about it.
hey…thank you for the answer…but the trick is, that downgrading it back to 19278 also doesn’t make it work, BACK
Right. This is an issue with a Waze update. This is independent from SYNC.
