In the process of downloading the software, I’m getting the error message: “Unable to read data from the transport connection: The connection was closed.” I’ve tried 3 different internet connections, including a mobile hot spot, and still get the message. I can’t seem to find a thread that has this issue yet. Any suggestions? Thank you.
Running the CI build now - I’ll let you know how we progress. Thank you.
You get 8% in before the issue, can you share your exact options i’ll try the same
I’m having the same issue. I’ll follow this thread.
Other than the USB flash Drive, my settings are identical.
If you unselect the Gracenotes package and try do you get the same error, trying to determine if it’s that specific package.
Same thing for me. I removed the GraceNotes package as well.
Same thing it fails to validate over and over
Please try the release branch again, it should download 2.4.0 it seems this is something that was changed between 2.4.0 and 2.4.1
It appears we are cooking now - Thanks again for your help! I’ll let you know after the download is completed.
I have restarted my computer system and started the download process over again. It appears to be further than we just were. I’ll let you know how hit goes.
I have pushed a new CI Build please test it out
