FORScan Supported Adapters, Protocols, and Platforms
NOTE: This information is an excerpt from the FORScan home page. FORScan Home
Supported adapters:
- OBDLink EX USB, recommended USB adapter for Windows version of FORScan, also for configuration and programming functions
- OBDLink MX+ BT, recommended Bluetooth adapter for Lite versions of FORScan (iOS, Android)
- OBDLink SX/LX/MX
- ELS27 (STN1170/2120)
- ELM327-compatible (fully compatible with original ELM327, please also see important note below)
- J2534 Pass-Thru
Important note: after many years of continued project development, even those of few ELM327 that have relatively good quality, ceased to meet all of the FORScan requirements. Besides, majority of the adapters that are being sold under ELM327 trademark have quite dubious quality that dropped a lot in the past: in fact, they have nothing common with the famous “ELM327” brand but name. Thus we do not recommend any “ELM327” anymore. If possible, please use adapters recommended above. FORScan will continue to support ELM327 adapters, but some new functionality may be limited or refuse to work on outdated adapters.
Supported protocols and bus:
- FORD HS CAN
- FORD MS CAN (only for J2534-2, CANtieCAR, OBDLink EX/MX/MX+, ELS27 or modified ELM327)
- FORD SCP
- FORD 9141
- FORD UBP (only for Ford VCMII)Supported modules:Almost all of modules availabe through supported protocols. Full list is here.Supported platforms:
Windows 2000/XP/Vista/7/8/8.1/10/11 (ELM327-compatible adapters with COM, USB, Bluetooth and WiFi interfaces, J2534 PassThru adapters).
Note: only x86/x64 architecture is supported for Windows. ARM architecture is not supported!
IOS v9.0 and higher (OBDLink MX+, ELM327 BLE and WiFi adapters)
Android v4.0 and higher (ELM327 Bluetooth and WiFi adapters) Platforms in development:
Windows Phone 8 (Bluetooth and WiFi adapters) - development stopped.
