Using the latest Forscan v2.3.59 I had taken a backup of the APIM prior to making any changes to a 2018 Sync3 unit that I had installed into my 2017 Ford Ranger and I have put the original Sync3 Screen/APIM unit back in. When I try to go into the APIM module in Forscan to make sure all is OK by restoring the APIM backup I took, Forscan gives the usual warning about making changes and, as soon as I click OK, it throws the error “Service procedure has been interrupted” and I can go no further.
I was hoping to use Syn3 Updater to go from Sync3 3.0.20204 to the latest 3.4 but am loathe to do this whilst this error and inability to restore the APIM ASBUILT hangs over my head…![]()
Is there any way to restore that backup or the factory ASBUILT I’ve also downloaded?
PS…I just thought, whilst the newer APIM module was installed, the system was connected to my Wi-Fi and tried to do a Sync update and stored different data online. Is that possible?
SYNC Region: ANZ
Old SYNC Version: 3.0.20204
New SYNC Version: 3.0.20204
Forscan error: Service procedure has been interrupted
