is possible update my 3.4.22110 to new 3.4.22251 with automatic install without reformat?
Old SYNC Version: 3.0.20204
New SYNC Version: 3.4.22110
how do i get it?
Yes, use the autoinstall method.
i think with this configuration?
Yes, that looks correct. (It’s in Italian?)
many thanks but i have another question…
is possible update only the maps ?
Yes
In the map version pull down menu there is an option for that.
do you know some problem with this new version 3.4.22251?
This version has been stable. If you experience any issues, I would recommend version 3.4.21265.
how many time required for update only the map?
About 90 minutes for autoinstall for a full EU map set. But you should be able to use reformat for the maps since you have a 2019 Mondeo. That will be about half the time.
Run the APIM Interrogator Utility in the Syn3 Updater, in the tool page, and post the results here. This will confirm your APIM model and ensure you are ok to use the reformat method.
VIN: WF0DXXWPCHJA40286
Versione 5U5T-14G381-EZ
Modello di APIM: Unknown
Tipo di APIM: Navigation
Capienza APIM: 64GB
APIM Spazio Libero: 11G
03/01/2023 16:55:59 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 1.0M / 1.1G
/fs/sd/MAP/ = 14M / 2.8G
/fs/sd/MAP/ = 14M / 2.3G
/fs/sd/MAP/ = 7.8M / 1.5G
/fs/sd/MAP/ = 17M / 2.2G
/fs/sd/MAP/ = 21M / 3.8G
/fs/sd/MAP/ = 336K / 38M
/fs/sd/MAP/ = 5.6M / 3.2G
/fs/sd/MAP/ = 25M / 3.2G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 29M / 4.8G
/fs/Nuance/ = 25M / 4.3G
/fs/Nuance/ = 35M / 3.6G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 786M / 1.2G
/fs/rwdata/quip/ = 22M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 11G / 54G
Installed Packages
1U5T-14G421-BAJ
1U5T-14G421-BBJ
1U5T-14G421-BCJ
1U5T-14G421-BDJ
1U5T-14G421-BEJ
1U5T-14G421-BFJ
1U5T-14G421-BGJ
1U5T-14G421-BHJ
1U5T-14G421-BJJ
5U5T-14G391-AS
4U5T-14G422-BAG
4U5T-14G422-BDG
4U5T-14G422-BBG
4U5T-14G422-BCG
4U5T-14G423-AC
1U5T-14G658-AH
APIM AsBuilt
DE00: BLANK
DE01: BLANK
DE02: BLANK
DE03: BLANK
DE04: BLANK
DE05: BLANK
DE06: BLANK
it’s ok?
wHaT DO YOU THINK?
i think i can choose this option to proceed with reformat method!?
Was the APIM in the vehicle replaced by Ford? Or replaced at all?
The VIN OEM build sheet shows the APIM as a JR3T-14G371-FFB, which is a Ford Service Replacement APIM. I would NOT reformat this unit as it most likely is MY20 APIM.
You should use autoinstall for all of your changes.
DO NOT REFORMAT.
APIM Info:
F10A>GB5T-14G379-AA
F110>DSHB5T-14G371-CA
F111>HL1T-14G380-CB
F113>JR3T-14G371-FFB
F124>HB5T-14G375-FA
F141>LXBE00BM
F16B>HB5T-14G379-BA
F188>HB5T-14G374-CA
Was the APIM in the vehicle replaced by Ford? Or replaced at all? :i down now!
is very strange …my car is made end 2018!
I would error on the side of caution. Just use autoinstall method for the upgrades.
There are 5 threads here describing issues with this unit.
Search results for ‘JR3T-14G371-FFB’ - CyanLabs Official Community
ok
for update only the map or only the firmware is necessary select in this method?
