Getting warning of region mismatch
Setting up the updater, and I’ve downloaded the files when I try to continue it pops up “The current region and your selected region do not match, this may not work!”
My region is USA & Canada
Maps are set to the USA & Canada
Okay to continue? First time using this software, but have used Forscan for several years.
Old SYNC Version: 3.0.18093
New SYNC Version: 3.018093
Haven't gotten that far
If you have configured Syn3Updater for NA and you chosed NA as desired versions, then it’s ok to ignore the warning.
Thank you for your fast reply!!
