12elotro
(12elotro)
20 February 2025 21:11
1
Have the maps been updated correctly?
I have updated to Sync version 3.4.23188 via the Ford website, the log file has been created and uploaded to the Ford website.
I then downloaded the Maps update, version F13, installed them but had several problems and am not sure if they were installed correctly. No log file was created but navigation works and system information shows F13
I have used the Interrogator tool, created the log file but am unsure whether to upload it to the Ford website in case I am validating a wrong update.
http://www.ford.co.uk/content/dam/guxeu/rhd/central/owners/resources-and-support/sync-%26-bluetooth-support/update/documents/Interrogator_AD.zip
Is there a way to check that the maps update was done correctly?
I don’t want to start the update from scratch because they are maps of Europe and it is very long
I know this has nothing to do with the Cyanlabs application but if someone can help me…
Old SYNC Version: 3.4.23188
12elotro
(12elotro)
13 March 2025 17:13
3
This is the log file created with the Interrogator tool.
I deleted the VIN number.
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2025-02-20" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>*****************************</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>NU5T-14G381-AD</d2p1:Response>
</d2p1:DID>
<d2p1:Response>315535542d3134473432312d42414c000000000000000000315535542d3134473432312d42424c000000000000000000315535542d3134473432312d42434c000000000000000000315535542d3134473432312d42444c000000000000000000315535542d3134473432312d42454c000000000000000000315535542d3134473432312d42464c000000000000000000315535542d3134473432312d42474c000000000000000000315535542d3134473432312d42484c000000000000000000315535542d3134473432312d424a4c000000000000000000315535542d3134473635382d414800000000000000000000345535542d3134473432322d42414c000000000000000000345535542d3134473432322d42424c000000000000000000345535542d3134473432322d42434c000000000000000000345535542d3134473432322d42444c000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415400000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>315535542d3134473432342d424e00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>8c525ec2</d2p1:Response>
</d2p1:DID>
<d2p1:Response>c4769812</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0a6a059a10224e0a06c2</d2p1:Response>
</d2p1:DID>
<d2p1:Response>53500101c00b489004804c04</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0203000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>00001d00240107</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1ac21aa42bd0</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>0700b300000000171c0000565600006a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-1U5T-14G371-EL</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GU5T-14G380-FF</d2p1:Response>
</d2p1:DID>
<d2p1:Response>LU5T-14G371-GNC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1U5T-14G375-HA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>N0AG019D</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>1U5T-14G374-EL</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>80:f5:b5:3c:78:34</d2p1:Response>
</d2p1:DID>
<d2p1:Response>80:f5:b5:3c:78:35</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2025-02-20T21:21:14+00:00" RAM="775512064" vmcuVersion="Vector_VMCU_05.04.27">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.2G" available="976K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.0G" available="15M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.4G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.6G" available="7.8M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.4G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.7G" available="26M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="41M" available="312K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.4G" available="4.9M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.4G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.9G" available="29M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="5.0G" available="30M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.5G" available="26M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="3.8G" available="37M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1003M" available="21M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="936M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
<d2p1:PartitionHealth type="/fs/mp/resources" total="72M" available="332K"/>
<d2p1:PartitionHealth type="/fs/images/" total="54G" available="9.5G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
In order to obtain this information you can upload the log file tho this website thru the Syn3 Updater process or see this tutorial, Tutorial: APIM Interrogator Utility/Create Interrogator Log - Ford / Guides - CyanLabs Official Community .
From the log file:
You have no DTC’s (Diagnostic Trouble Code) in the APIM.
The installed Sync app is NU5T-14G381-AD.
The installed options are:
didValue=“8060”
didValue=“8061”
When you put these values thru a Hex to Decimal converter, you get the installed packages:
1U5T-14G421-BAL
1U5T-14G421-BBL
1U5T-14G421-BCL
1U5T-14G421-BDL
1U5T-14G421-BEL
1U5T-14G421-BFL
1U5T-14G421-BGL
1U5T-14G421-BHL
1U5T-14G421-BJL
1U5T-14G658-AH
4U5T-14G422-BAL
4U5T-14G422-BBL
4U5T-14G422-BCL
4U5T-14G422-BDL
4U5T-14G423-AC
5U5T-14G391-AT
1U5T-14G424-BN
You APIM storage looks like this:
<d2p1:AdditionalAttributes logGeneratedDateTime=“2025-02-20T21:21:14+00:00” RAM=“775512064” vmcuVersion=“Vector_VMCU_05.04.27”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.2G” available=“976K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.0G” available=“15M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.4G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.6G” available=“7.8M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.4G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.7G” available=“26M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“41M” available=“312K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.4G” available=“4.9M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.4G” available=“27M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.9G” available=“29M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“5.0G” available=“30M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.5G” available=“26M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“3.8G” available=“37M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“1003M” available=“21M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“936M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“72M” available=“332K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“54G” available=“9.5G”/>
Looks normal for an EU map install.
