Question: is the unit still under warranty? You mentioned it was changed about a year ago, that’s why I’m asking…
Nope, called them yesterday unit is 14 month old
Is it the screen that’s gone or the apim unit
The APIM is not booting because the video drivers are now bad. It could be possible to rescue the unit, no guarantees.
Sync 3.4 Black Screen
NOTE: This procedure is not guaranteed to work, and you are responsible for your actions. This is posted for information only.
MY20+ APIM may exhibit a black screen if the reformat tool is used. This is because the screen drivers are not supported by the reformat tool above. Depending on the eMMC version, there are two methods to correct this issue.
A) APIM is a MY20+ with an ‘old eMMC’ type.
B) APIM is a MY20+ with a ‘new eMMC’ type.Solution for case A) Plug the APIM to an old screen and complete the reformat.
- Change the screen to an older one, force reset the APIM with FORScan and power cycle the APIM.
- Fix the install and update as usual, then…
- Optionally, change back to MY20 screen and force reset the APIM with FORScan and power cycle again to make it work.
Solution for case B) You need to flash a working eMMC dump using an eMMC reader.
Actually there are 2 issues afaik
The newer screen requires new drivers which the reformat tool does not have
The emmc flash chip on newer APIMs is not supported by the reformat tool
In this case I believe it’s the latter so unlikely to be fixable
This could be an option for solution B using the eMMC dump. Where would i get the flash bud?
Can I not reflash this back with old software
There are resources available in the UK. We do not deal with that here.
Only via eMMC flash.
Take the APIM apart and send me pictures of both boards, if it’s a pre MY20 board it might be flashable
Will do, ive emailed Ford customer care and see i can push for a replacement as its only 14month old.
Hello Simon.
I was wondering how your case was doing.
Did you receive any positive feedback from Customer Care?.
Still in the process with them now, but takes them ages as had to escalate to customer care
In regards to the emails you sent, please provide pictures of the internals of the APIM as requested 1 month ago. until then i can not help.
J series, Manufacture Date December 2020!!! ![]()
Added bud
Definitely a service replacement APIM with new eMMC.
@simon_rogers want to sell me the APIM? will be useful for testing.
