Good afternoon everyone.
I’ve got the interrogator tool (the AD version, because the AA version didn’t get the AsBuilt info, was all blank) and ran it on
my Ecosport 2019 SE 1.5 AT that I got from a reseller so I don’t know the maintenance history.
I’ll paste the info I got here and want some help identifying what are the odds of it being a MY20 or not, because I wanted to upgrade it from 3.0.17276 to 3.4, jailbreak and use some mods, specially the videoplayer mod.
The log of the interrogator tool:
Versão JR3T-14G381-AJ
Modelo APIM: Blank
Tipo APIM: Non-Navigation
Tamanho APIM: 8GB
Espaço Livre APIM: 1.5G
06/08/2023 14:52:38 +00:00
Well, the interrogator is not showing that information, so we can only guess. It should not be MY20 based on the car’s year and Sync3 version, but it’s only a guess.
If you want to be sure you will need to unmount the unit and check the stickers.
Another thing you could do is trying to update it to the latest 3.0 via Ford’s site. Maybe the latest 3.0 will give back that information when running the interrogator.
Thanks for the answer.
Tried that already but the Ford website says the latest version available was already downloaded and the file can be downloaded only once, so no deal.
Isn’t there a way to find out using Forscan? I have a Ford compatible USB OBD adapter I used when I had a 2014 Fiesta, so if you point me to some tutorial I would follow it.
And if i decide to try to update to the latest SYNC3 version and get the unit bricked, would it be possible to recover it or just replacing it?
Again, thanks for the help!
That’s odd, Ford released a build for 3.0 in 2020, so the latest should not be one from 2017… I’m guessing there’s some history behind this, since you are not the first owner, we do not know what it is .
You.could install it manually though, we have it in our DB.
Of course, you didn’t mention you have Forscan and a scanner before. But in Forscan, go to the APIM module and check it.
That depends… If it’s bricked due to MY20 hardware being present, you would need to replace it.
Sorry, used it just 2 times and forgot about it, remembered while replying.
I will try it and see if it reports the version.
So, if I couldn’t tell for sure I can safely upgrade, that’s a big no for me. Live in Brazil, and those things are expensive as hell here. Can’t risk it without knowing for sure it is safe.
Yes, that is really odd. I insert the VIN and ir reports the exact version that is installed and says it is the latest available.
But cool to know I can install it manually.
