(redacted vin) ECU CONSUMER OTA SYNC OTA 7D0 4U5T-14G381-AN false 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 false 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 false 576be4c4 false ba085293 false 006a05ca1000bc0440c0 true 554b0001c08a088028b80005 true 0000010004 true 00001de1010000 true 190819082653 true 40 true 0b0533000000006428000056565d0061 true DS-GB5T-14G371-DG false H1BT-14G380-DB false JK2T-14G371-ACC false GB5T-14G375-AB false NX48026K false 00 false 00 false GB5T-14G374-DG false
not sure if i left the usb in the car long enough was only a few seconds
That’s wrong, upload the file itself, not sure what you pasted.
InterrogatorLog() +
CopyInterrogatorLog +
The esn is NX48026K
The VIN number is
that maybe?it says im not authorised to upload files
ill try and do it again now
Try again to attach it, you should be able now
APIM size is 16GB and it says i have 10GB free is that too full?
Please, stop posting so many messages one after the other… Post one with all the info, is easier to track.
You have plenty of free space, it should work.
Are you using an USB stick or external hard drive?
I wonder if the partitioning is wrong in the APIM…
USB stick
The only item installed on the APIM is the Sync 3.3.19052 app file. I recommend that you reformat this unit from 3.3.19052 to the current Sync 3.4.21194, with the new voice file and DAB file. DO NOT install Gracenotes with these files.
Files for Sync 3.4.21194:
APPS - 5U5T-14G381-ET_1627475308000.TAR.GZ
VOICE - 5U5T-14G391-AP_1626914045000.TAR.GZ
ENH_DAB - 1U5T-14G658-AG_1626915602000.TAR.GZ
After these files are installed, run the Interrogator tool and see what the storage indicates.
Gracenotes installation after successful installation of the above files:
4U5T-14G423-AC_1615425645000.TAR.GZ
NOTE:
It is very unusual for there to be only an app file installed without any others. It appears that the unit was reformatted from Sync 3.0, as the model in question were OEM with Sync 3.0. If that is the case, the reformat did not finish the installation, looking at the partition structure above. This is why I suggest to just reformat the unit and fix it properly.
EDIT:
Now I remember, you used another update that did not agree with your car.
Downloading Sync 3 update with Nav in a car without Nav. - Ford / Sync 3 - CyanLabs Official Community
The resolution was to install the files similar to above.
Should I changed the advanced settings from auto-detect to reformat? I just tried to do this with auto detect and nothing happened.
Yes, you are correct, you need to force the installation method to REFORMAT.
Since it’s not a MY20 or later unit, it will be cleaner and faster. Please check Easily Update SYNC 3 Using Our Automated Method - CyanLabs for details, especially the section titled “Updating (Reformat Mode)”
Thanks F150chief for confirming partitioning was wrong, and also remembering this was a double post actually; issue should be solved by now.
