How to download sync 3 previous versions on here?
I need version 2.2.17011 that I did not update to first before updating to version 3.0 and my 2016 mustang apple carplay is not working. This site is does not lead you anywhere for that.
Old SYNC Version: 1.0
New SYNC Version: 3.0
no
Build custom USB that only installs that file,
I downloaded both the file and the auto installation file. I copied both over without unzipping anything and nothing. Do I need to unzip all files? Do I need to put the auto installation file on there?
Drop the file into a directory called SyncMyRide and put the autoinstall in the root of the drive.
Let me guess, you didn’t spend some time searching and after a quick time you just said “this site does not lead to that”…
But sure, “This site is does not lead you anywhere for that.”…
Also, to be fair, this site is mainly for upgrading to 3.4… So anything for 2.x and 3.0.x should fall under Ford’s realm… But even so, information for that is located here as well…
