Bean5.0
(Isaac Tapia)
March 19, 2025, 7:09pm
1
i updated to newest sync3 version available in the app
my apim is a 2017 model and my vehicle is 2021, i think this car came with what is necesarry to use ford pass but as of right now i can get it to connect, i have the app and add the car but cant go farther than that, not sure if it is possible to get it to work.
APIM Model: JR3T-14G371-CED
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 3.7G
Version 3.4.23188 (NU5T-14G381-AD)
3/19/2025 7:20:27 PM +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 12M / 1.6G
/fs/sd/MAP/ = 12M / 1.5G
/fs/sd/MAP/ = 10M / 1.5G
/fs/sd/MAP/ = 3.1M / 1003M
/fs/sd/MAP/ = 8.3M / 1.3G
/fs/sd/MAP/ = 14M / 1.8G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 6.4M / 1.3G
/fs/Nuance/ = 16M / 1.7G
/fs/Nuance/ = 10M / 1.1G
/fs/Nuance/ = 23M / 2.5G
/fs/Nuance/ = 3.2M / 465M
/fs/rwdata/ = 973M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/images/ = 3.7G / 25G
Installed Packages
4U5T-14G421-CJG
4U5T-14G421-CHG
4U5T-14G421-CGG
4U5T-14G421-CFG
4U5T-14G421-CEG
4U5T-14G421-CDG
4U5T-14G421-CCG
4U5T-14G421-CBG
4U5T-14G421-CAG
5U5T-14G391-CS
4U5T-14G422-CCN
4U5T-14G422-CBN
4U5T-14G422-CAN
4U5T-14G423-CC
APIM AsBuilt
DE00: 6A2A010200020800008A
DE01: 55530902C002008000000005
DE02: 0000010100
DE03: 01000900060001
DE04: 1856195A29D6
DE05: 80
DE06: 100033000000000B65000056566D004C
F150Chief
(F150Chief)
March 19, 2025, 8:29pm
2
Could you run the Interrogator Utility again and post the new log here…in the previous one you had 2 DTC’s. Find out what those are and clear them using FORScan. Also make sure that the modem serial number is displayed on the screen in Sync 3 info.
The APIM looks to be a JR3T-14G371-CED, SN WWAK7BDF. The firmware and info in the log file indicate the unit has never been upgraded, it is at 2017 production firmware.
Also, is the vehicle running when you are trying to authorize it?
Bean5.0
(Isaac Tapia)
March 20, 2025, 2:22am
3
ran the interrogator tool and finally got a working xml, i updated the log file to the new one,
yes i do run the vehicle when attempting to authorize
Bean5.0
(Isaac Tapia)
March 20, 2025, 2:31am
4
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance ” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2025-03-19” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>xxxxx1</p:VIN>
<p:RequestRole>
d2p1:Role CONSUMER</d2p1:Role>
d2p1:RoleSource OTA</d2p1:RoleSource>
d2p1:RoleDesc SYNCGEN3</d2p1:RoleDesc>
d2p1:RoleID OTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue=“c184000b”/>
<d2p1:DTC DTCValue=“c238000b”/>
</p:BroadcastDTCType>
d2p1:Address 7D0</d2p1:Address>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response NU5T-14G381-AD</d2p1:Response>
d2p1:IsConfig false</d2p1:IsConfig>
</d2p1:DID>
d2p1:Response 345535542d3134473432312d434a47000000000000000000345535542d3134473432312d434847000000000000000000345535542d3134473432312d434747000000000000000000345535542d3134473432312d434647000000000000000000345535542d3134473432312d434547000000000000000000345535542d3134473432312d434447000000000000000000345535542d3134473432312d434347000000000000000000345535542d3134473432312d434247000000000000000000345535542d3134473432312d434147000000000000000000355535542d3134473339312d435300000000000000000000345535542d3134473432322d43434e000000000000000000345535542d3134473432322d43424e000000000000000000345535542d3134473432322d43414e000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:Response 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:Response 93f6e1c0</d2p1:Response>
</d2p1:DID>
d2p1:Response 5b34fa5f</d2p1:Response>
</d2p1:DID>
d2p1:Response 6a2a010200020800008a</d2p1:Response>
d2p1:IsConfig true</d2p1:IsConfig>
</d2p1:DID>
d2p1:Response 55530902c002008000000005</d2p1:Response>
</d2p1:DID>
d2p1:Response 0000010100</d2p1:Response>
</d2p1:DID>
d2p1:Response 01000900060001</d2p1:Response>
</d2p1:DID>
d2p1:Response 1856195a29d6</d2p1:Response>
</d2p1:DID>
d2p1:Response 80</d2p1:Response>
</d2p1:DID>
d2p1:Response 100033000000000b65000056566d004c</d2p1:Response>
</d2p1:DID>
d2p1:Response DS-HB5T-14G371-CA</d2p1:Response>
</d2p1:DID>
d2p1:Response HL1T-14G380-BB</d2p1:Response>
</d2p1:DID>
d2p1:Response JR3T-14G371-CED</d2p1:Response>
</d2p1:DID>
d2p1:Response HB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
d2p1:Response WWAK7BDF</d2p1:Response>
</d2p1:DID>
d2p1:Response Blank</d2p1:Response>
</d2p1:DID>
d2p1:Response 03</d2p1:Response>
</d2p1:DID>
d2p1:Response HB5T-14G374-CA</d2p1:Response>
</d2p1:DID>
d2p1:Response </d2p1:Response>
</d2p1:DID>
d2p1:Response 9c:1d:58:46:8a:da</d2p1:Response>
</d2p1:DID>
d2p1:Response 9c:1d:58:46:8a:db</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2025-03-19T19:20:27+00:00” RAM=“1050058752” vmcuVersion=“Vector_VMCU_05.02.08”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.6G” available=“12M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“12M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“10M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1003M” available=“3.1M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.3G” available=“8.3M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.8G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.7G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.3G” available=“6.4M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.7G” available=“16M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.1G” available=“10M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“2.5G” available=“23M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“465M” available=“3.2M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“775M” available=“5.8M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“973M”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“25G” available=“3.7G”/>
d2p1:InstallationLog/
d2p1:SyncData MIIEtAYJKoZIhvcNAQcDoIIEpTCCBKECAQAxggG4MIIBtAIBADCBmzCBhjEbMBkGA1UEChMSRm9yZCBNb3RvciBDb21wYW55MQswCQYDVQQGEwJVUzERMA8GA1UEBxMIRGVhcmJvcm4xHjAcBgkqhkiG9w0BCQEWD21nbXNlY0Bmb3JkLmNvbTEnMCUGA1UEAxMeU3luYyBNb2R1bGUgRW5jcnlwdGlvbiBHZW4zIEEyAhDfwyMpAoa+v0vYmqleqJR7MA0GCSqGSIb3DQEBAQUABIIBABLTDmWOdvloUQF7bGCyvbU9/b85uyFDn8OmmAtGCUiQEOgLOftB4J5+S0axmV/Km7ubE67FEWb21VRwvpj6CwmI3j1O5rxfxuFpA2a5oZm8mcsCIm14Cw68JbEWV+tP5bUOUL+vaKR7gtyPYNoPWy7nok5ZI3TF51T1FASaIELU59p7xt/53zpQZm0eLK/lwsyJMWj0NJ5woRbHAg27P6OrJaYL4IHz/Wi/Hfz2Iku6ujQNQhe9Pq0ivH4wfWCP4281F2gzy8SveztypfUezXVqtB8yg9G2luMprwg5F5G9EDfXVS3wFpod1FZHD4gbRSNwzdOZZh7DTT+hgY2dvykwggLeBgkqhkiG9w0BBwEwHQYJYIZIAWUDBAEqBBBjHRkdqEFsWilCBTbEHCm4gIICsO62qEQJ1Sl0NJpFFeaJucT5DeOYO3WYMePuDuXxPvHVAOD/4DF/rfPqrazOZ1xV1Ow8cFW8NjHmsc/Akjw9a5/OdQIZfV+q99i9gDZG77TOBn3+6CQmV9OjZtjTDSto0FKlYDPI9OSsQuBX2T9LqOCr5Oj5QT8mZpzDujFibECNOMghsQwo1mNiRXtqzzuAN7/nlB/jc828bJXEz8+UJxvlfxkINmmqYSsDBPAAfK1bmawZc7xzggAC4ZmPaUww627xDkwpoiJJuNxg2sMHCC8/ph/kh0cQoSA7h7hdVAeN3EUUvR0utkk+VFLeWklhcmAXTIA8v0oPZKoqx0ojOSTz5kA1H4eQ/1NLQejG11v/PeJ7poRSkKSLlAMRAFehMKJ4MGNhGbVIT0jV7nI7GqVZmWmNagVcsixcy7Z2RvyLipr3Ei5cZQ8pQL+aZsxMMzd3+37ZZKJZs8JvtP5cSHhRpEvMmCUqRwISKVPxbeYiYxGpvvJMZphmMOuksCS3ySET124899UiSmNdvdV/Fw5oyL+NCQ3vYj5Zpri6wJoLsZD2+Uzny+L6hMJKxHCXe7IisoAoZedF/s7rmjFbBHZsSDlbThIwoPDaNBadq6vAUiuJxbG8PyixMDXyDJnpNcJbD28FHz6JmmTkquRkUSGWXPi6sPHuYygEY2RFUmmEb3Ki2GIUh0GtqZjsk1+op+jWSaMbHqqqc7eClnC29iuk/otsKD2sy9ENqeGbu9IvzIZNKf5woKZEqDkoq1Z3trhPUmLJBHKwZ0q6aPGqw/6PL7HHSsq4nd1bE5Rxj9PTa6NJqUCNLC0dq2cz5xG/4FhC+tV+e2Xs5gxhERbCS5SwadidEXj8dCvMRa23Ak3YPC3o0fKPgopCuUWCw6w4OaS3dk2FUGOfI7RTRdC3Dlk=</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
F150Chief
(F150Chief)
March 20, 2025, 3:01am
5
Having the older generation 2017 APIM rather than a MY18.5+ might be a challenge to getting FordPass to work in a 2021 vehicle. But, you have APIM settings to correct.
DE01:
Instruct the APIM there is a TCU.
7D0-02-02 xxxx *xxx xxxx, from 8 to 9. (0200 8000 005D to 0200 9000 00xx)
Instruct the APIM that the TCU is hotspot capable.
7D0-02-03 *xxx, from 0 to 4. (0005 E1 to 4005 xx)
Correct these settings and reboot Sync, see if the modem appears in the Sync info screen. A master reset may be required. Once this is done try the authorization procedure again. If the modem does not show up in Sync, it is likely you will need to upgrade the APIM firmware to MY18.5+ version.
Bean5.0
(Isaac Tapia)
March 20, 2025, 3:07am
6
Thank man, sounds like you know your stuff, i appreciate it, ill give it a try tomorrow
bill32399
(bill32399)
March 20, 2025, 4:57am
7
A 2021 would use an L+ series TCU on HS4. The J series APIM’s cannot use HS4 even though there is an option to turn it on. You would need a K series APIM with the latest Calibration to get HS4 to work with at least an upgraded K series TCU.
The current configuration will never work.
Bean5.0
(Isaac Tapia)
March 20, 2025, 3:51pm
8
In Apim as built for 7d0-02-03 it stops at E1 no more code to change
Bean5.0
(Isaac Tapia)
March 20, 2025, 11:55pm
11
Read it wrong sorry, changed the as built and setting says “onboard modem serial number (esn): “
No serial number, maybe previous owner removed TCU because in forscan I get a 2 dtc’s
Code: U0184 lost communication with radio status (-0B)
And
Code U0198 lost communication with telematic control module ‘A’ status (-0B)
Bean5.0
(Isaac Tapia)
March 21, 2025, 12:13am
12
I did go into setting and enable tcu reset and the code you told me for as built and got rid of the dtc that said it couldn’t communicate with the tcu, FordPass connect showed up in the setting though
Edit: same error code came back but FordPass connect still shows in settings
F150Chief
(F150Chief)
March 21, 2025, 2:23am
13
Do you see the modem serial number on the APIM info screen? Like this…
If it is not and you have made the 2 settings above, then the issue is one of 3 things:
There is no TCU in the vehicle.
Your present APIM needs to have the firmware upgraded to MY18.5+,
or
The APIM will not work in a 2021 vehicle due to the lack of HS4 network to communicate with the TCU as @bill32399 stated above.
I would agree with @bill32399 that the APIM is not compatible.
