How to hide Navigation Button?
Hi,
I have APIM with NAV. This device was brought into EU from North America. I can’t install all EU maps so I always have to manually “castrate” the update when there is a new version. I want to convert my device to Non-NAV programmatically, or just disable NAV button on device main screen.
I have installed Non NAV update 3.4.20.282 recently but unfortunately the button is still there. And when I press it I see Navigation malfunction error message. I rarely use Ford build-in navigation as there are many Apple CarPlay options out there. Which are by far better that the built-in one.
Is there any way I can hide this button? Anything to do via ForScan?
Many thanks
This will disable it:
7D0-01-02: #X##-####-####
Set above to zero:
0 = USB2 Disabled, Navigation Disabled, Rear EFP Disabled
Thank you! Will try this approach
Many thanks mate!
I followed you advise and disabled navigation.
