How to Troubleshoot Sync 3 Update Stuck at "Installing Update" Screen?
Hello everyone :smiling_face_with_three_hearts:
I am having a bit of a meltdown with my Ford Sync 3 update! Been following the CyanLabs Syn3 Updater guide to a T, but my system’s been stuck on “Installing Update” for hours now. Not exactly progress city.
Here’s the situation:
Sync Stuck in First Gear: Currently running Sync 3 version 3.0, and trying to shift it into the latest CyanLabs gear.
USB Drive Ready to Roll: Using a 32GB USB drive, formatted to exFAT and loaded with the update files, just like the instructions say.
My trusty steed: My vehicle is a 2018 Ford F-150.
Tried Restarting Everything: Restarted the truck, jiggled the USB drive in and out, even waited patiently (for a really long time), but the update screen is like a stubborn mule - won’t budge!
Wondering if anyone has a clue what might be causing this or how to get things moving again. Maybe someone else has faced this update roadblock and has some wisdom to share?
I also check go through this source: https://community.cyanlabs.net/t/stuck-at-insert-usb-stimendix
Thanks in advance!
Respected community :innocent:
Deniz Can
What’s actually on the screen right now?
Do you have the standard Sync3 screen, the Mustang or ?
Hello.
I’m not sure why you didn’t create a thread with the template, that would give use a lot of information.
So, lets make this simpler:
A) provide the log for the usb you are using for upgrading
B) create and run an interrogator log against the unit, then share the produced XML with us
