Installed non nav sync in a nav enabled sync
I installed the non nav update when i have a nav version, Should I run the reformat and install the correct one? Only issue is that Android Auto wont launch. Is my APIM toast?
Old SYNC Version: 3.4.22251
no
Syn3 Updater Version: 2.12.4.0
CYANLABS - SYN3 UPDATER - V2.12.4.0
Version: 3.4.22251
; CyanLabs Syn3Updater 2.12.4.0 Stable - Autoinstall Mode - Sync 3.4.23188 NA
FILES (4)
[1/9/2024 19:50:57] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[1/9/2024 19:50:57] Install Mode: Auto-Detect (autoinstall) Forced: False
[1/9/2024 19:50:57] MY20 Protection: Auto-Detect
[1/9/2024 19:50:57] Formatting USB drive
[1/9/2024 19:50:57] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[1/9/2024 19:51:05] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/9/2024 19:51:05] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/9/2024 19:51:05] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/9/2024 19:51:05] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/9/2024 19:51:05] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/9/2024 19:51:05] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/9/2024 19:51:24] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/9/2024 19:51:25] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/9/2024 19:51:25] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/9/2024 19:51:25] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/9/2024 19:51:50] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/9/2024 19:51:52] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/9/2024 19:51:52] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/9/2024 19:51:52] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/9/2024 19:52:27] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/9/2024 19:52:29] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/9/2024 19:52:29] Preparing USB drive
[1/9/2024 19:52:29] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/9/2024 19:52:29] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/9/2024 19:52:29] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/9/2024 19:52:29] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/9/2024 19:52:29] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/9/2024 19:52:29] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/9/2024 19:53:13] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/9/2024 19:53:14] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/9/2024 19:53:14] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/9/2024 19:53:14] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/9/2024 19:54:29] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/9/2024 19:54:30] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/9/2024 19:54:30] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/9/2024 19:54:30] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/9/2024 19:56:25] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/9/2024 19:56:27] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/9/2024 19:56:27] Generating Autoinstall.lst
[1/9/2024 19:56:27] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Based on the log you provided, you should still have nav.
There’s no “NAV/NONAV” specific Sync3 package, they are both the same, map packages is what makes the difference.
Again, based on the log you provided, no need for that since you had maps installed.
That’s strange, did it work before?.
Have you tried unparing the devices, making Sync3 forget about the phone (and viceversa)?. Also, try a master reset.
EDIT: also keep this warning in mind, since I missed mentioning it:
You have a 2020+ APIM, if you reformat it than you will brick it.
Thanks for the quick reply, I don’t have the car right now. It’s at the stealership for the axel bolt recall. It didn’t do a master reset yet. I’ll give it try when it get it back… thanks again
I opened this topic so you can respond when you get your vehicle. Remember: DO NOT REFORMAT.
Actually power/ ffwd, solved the issue. Do miss being able to have climate controls in sync. My 21 Ranger had them. Any way thank all of you for your replies.
