Interrogator log creation - APIM as built information is blank
I used the Sync3 updater 2.12.5.0 to download the latest sync 3.4 updates and map version to a thumb drive. My current installed Sync3 version is 3.4.22251.
Before I start the installation of the new sync version I ran the “create interrogator log usb” to verify that my APIM is indeed compatible.
The car installed the interrogator file and I removed the thumbdrive from the car until display read installation complete. Hereafter I took the usb back to my computer and clicked step 3 .open interrogator log.
Here, the 3rd window reads: Apim as built, DE00 throughDE06: BLANK
Can I go ahead and install the latest 3.4.23188 version or will it cause issues?
Old SYNC Version: 3.0.20204
New SYNC Version: 3.4.22251
VIN: 1FADP5BU8GL117141
Version NU5T-14G381-AB
APIM Model: Unknown
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 4.2G
09/02/2024 1:03:30 PM +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 12M / 1.5G
/fs/sd/MAP/ = 12M / 1.4G
/fs/sd/MAP/ = 10M / 1.4G
/fs/sd/MAP/ = 2.9M / 951M
/fs/sd/MAP/ = 8.6M / 1.3G
/fs/sd/MAP/ = 14M / 1.8G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 6.7M / 1.4G
/fs/Nuance/ = 15M / 1.6G
/fs/Nuance/ = 10M / 1.1G
/fs/Nuance/ = 24M / 2.5G
/fs/Nuance/ = 3.2M / 465M
/fs/rwdata/ = 0 / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 87M / 90M
/fs/mp/ = 84M / 1.4G
/fs/images/ = 4.2G / 25G
Installed Packages
4U5T-14G421-CAE
4U5T-14G421-CHE
4U5T-14G421-CGE
4U5T-14G421-CJE
4U5T-14G421-CFE
4U5T-14G421-CEE
4U5T-14G421-CDE
4U5T-14G421-CCE
4U5T-14G421-CBE
5U5T-14G391-CS
4U5T-14G422-CCK
4U5T-14G422-CBK
4U5T-14G422-CAK
4U5T-14G423-CC
APIM AsBuilt
DE00: BLANK
DE01: BLANK
DE02: BLANK
DE03: BLANK
DE04: BLANK
DE05: BLANK
DE06: BLANK
If you reformatted tha APIM before, then yes, you should be fine.
This could be an issue though, your RWDATA partition is full…
Thank you very much SaNdMaN.
I will search the database/tutorial to reformat APIM.
I think I saw directions somewhere before I downloaded the sync update files to my thumbdrive. Hopefully I don’t make mistakes and have to replace APIM later
